Offline sebastian
#1 Posted : 14 June 2007 06:39:42(UTC)
sebastian
I have a question about MFX decoders. Since they register automatically on the CS, what happens if you have two identical locomotives, like two 39010, or something like that? confused From factory, they both come with the same address. How is this conflict negociated by the CS? Does the CS know this then assigns a new address that is not being used already?
DRG, DB and SBB
Era II, III and IV
Sincerely,
Sebastian
#2 Posted : 14 June 2007 07:39:12(UTC)
Sebastian,
Each Decoder has it own unique electronic Address or Serial Number that is assigned at manufacture, SO NO TWO decoders can have that Serial Number.
That is how they are recognised by the CS and MS.
a Good Example is Computer Network Cards. Each one has its own Serial Number or Address.
and that is used if you are not using IP Addresses for the Network.
Nev
Offline sebastian
#3 Posted : 14 June 2007 15:40:09(UTC)
sebastian
Thanks Nev. I am clear now. Smile
DRG, DB and SBB
Era II, III and IV
Sincerely,
Sebastian
Offline Hemmerich
#4 Posted : 14 June 2007 17:40:20(UTC)
Hemmerich
One additional remark:
Those two locos still have the same NAME; i.e. it looks like you might have the same entry twice. Simply grab one or both of them and change the name(s) as desired.
#5 Posted : 15 June 2007 02:16:39(UTC)
Thanks Lutz, I forgot that bit. [V](Signs of Old Age)[:I]biggrin
Offline sebastian
#6 Posted : 15 June 2007 06:12:37(UTC)
sebastian
Thanks Lutz. This is also important. biggrin
DRG, DB and SBB
Era II, III and IV
Sincerely,
Sebastian
This page was generated in 0.359 seconds.
