Offline efel
#1 Posted : 29 March 2007 13:39:50(UTC)
efel
I experienced my first failure in C track turnout motor yesterday.
The turnout did not respond to the control sent by the PC. After investigations it appeared that it was not an electrical failure, but a mechanical one: After removing the motor, I saw that the mobile rod was stuck (stongly stuck), at full stroke.
I can't understand what happened: nothing has burned (I opened the motor to check) , the end stroke switches are electrically and mechanically working, the coils have a standard 20 Ohm resistance.
Had Anybody already experienced this problem?
How can it be explained?
Thanks for your help
Fred
Offline dntower85
#2 Posted : 29 March 2007 18:46:39(UTC)
dntower85
Thats strange, could you move the rod after opening the motor?
DT
#3 Posted : 29 March 2007 20:41:13(UTC)
Where did you use K83 or 74460 decoder for the 74490?
Offline efel
#4 Posted : 31 March 2007 17:36:45(UTC)
efel
The rods can't move, even with the motor opened. Seems they are glued "inside" the solenoids. Probably something melted ?
#5 Posted : 01 April 2007 01:23:08(UTC)
two possibilities come to mind.
1) there is/was a short to the metal case which in turn shorted to the centre rail - result solinoid energised for a long time heating wire insulation/former/actuator(rod)
2) software is not sending a shutoff command (code Dec32). result = as above with solinoid energised too long.
Note: The later certainly applied to earlier motors with only one switch, however I am still wary of the actual design/adjustment of these cutoff switches. In some cases the rod has enough slop to allow the switch to 'not' activate.
Offline Lars Westerlind
#6 Posted : 01 April 2007 15:36:59(UTC)
Lars Westerlind
The motors have end shutoff contacts. Either not working, or a mechanical fault. I've no idea.
/Lars
Offline efel
#7 Posted : 03 April 2007 00:39:57(UTC)
efel
Thanks for your answers.
It's true that a permanent voltage is applied on the coil, and that a failure in the end shut off contacts would be critical. Up to now, they seem reliable....fortunately.
Nevertheless, I find it strange that the rod is "glued" at full stroke with the end contact opened, as it should be.
Fred
This page was generated in 0.408 seconds.
