Offline fmm
#1 Posted : 22 April 2005 14:31:36(UTC)
fmm
Hi All
I've recently acquired a second-hand Turntable 7286. I would like to use it in my digitalized layout, so that I have acquired a new 7687 set, which includes the 7686 decoder. But while I'm reading the instructios of the 7286, ops !!, it says that for turntables made on or before year 2002, a modification should be made in order to adapt the electronics of both 7286 and 7686. For this purpose, I should send both to my dealer (and he sent them to Germany, I guess)
Fantastic. Anybody knows what type of modification needs to be made ? How can I know the year of birth of my 7286 ?
Thanks a lot for your help.
fernando
Fernando
#2 Posted : 22 April 2005 15:51:01(UTC)
The serial number of the turntable maybe is the way to know the year
of construction.
Offline Timaximus
#3 Posted : 22 April 2005 16:25:03(UTC)
Timaximus
Look under your turntable.
There must be a date stamp.
It is on my new (2004) TT written with dark blue ink.
Offline Maxi
#4 Posted : 22 April 2005 20:26:46(UTC)
Maxi
Just a word of note, some people seem to have difficulty with this module. For me the module refused to work right out of the box.
After many hours of searching and looking at the circuit board I noticed that the sockets which are soldered to the circuit board seem to be touching the circuit board. There is a circuit which runs underneath the sockets which is not suppose to touch the sockets. I ended up putting a thin piece of plastic between the sockets and the circuit board. This solved my problem and the module worked for me.
I also remember seeing some notes and pictures on how the modification is done on the older turntables. I will check when I get home to see if I still have a copy on my computer.
Maxi
#5 Posted : 22 April 2005 22:41:46(UTC)
These turntables are never right, but they look so cool. I've been through 2 where the factory wiring diagram was incorrect and I spent hours wondering why the damn things wouldn't work. The worse part was that the wiring was different on each turntable! My current one also has a contact problem, the deck works and so does the tracks leading into the table, but the 2" perimeter deck tracks don't get power. Another weekend project I guess. Does anyone have experience with this?
Offline Sander van Wijk
#6 Posted : 22 April 2005 23:59:50(UTC)
Sander van Wijk
I don't have experience with the problem you mentioned John, but I do have some experience with the turntable decoders. It does indeed happen quite often these decoders don't work. Märklin will fix the problem (guarantee) but it's quite anoying though...
Sander
Offline pat
#7 Posted : 23 April 2005 04:18:22(UTC)
pat
My TT also does not run properly the power runs to it but has a problem with the decoder.When it comes back from the shop I will let you know whats wrong.5horizionsrr is right though "they look so cool"
worse things happen at sea
Offline fmm
#8 Posted : 26 April 2005 18:27:48(UTC)
fmm
Thanks all
I think it will be better to send the TT to my dealer and see what can he do with it.
In any case, I'd like to see your pictures on this, Tim. [:p] Thanks
Fernando
Offline Timaximus
#9 Posted : 26 April 2005 23:43:13(UTC)
Timaximus
Offline fmm
#10 Posted : 29 April 2005 19:33:41(UTC)
fmm
Hi all
Thanks Tim. My TT does not include any date, so I'm afraid it is a model prior to 2002 [:(] I'll sent it to my dealer.
Thank you very much in any case
Fernando
#11 Posted : 30 April 2005 00:39:39(UTC)
HERE IS THE PICTURE PLEASE CLICK HERE
http://www.msnusers.com/...ShowPhoto&PhotoID=21
THE TURNTABLE DATE LATE 2003 WITH DIGITAL DECODER 7686.
THE THREE LIGHTS INCLUDED DIODE (GREEN,RED AND YELLOW).Cool
Offline robertrt
#12 Posted : 21 May 2005 03:04:41(UTC)
robertrt
Gentlemen
I have a 7286 purchased last year. Included was the 7687 digital conversion kit. The bottom of my turntable is stamped 0689 so I assume it was manufactured in June of 1998. The instruction book included is also dated 0698. It does not state any modification necessary to convert to digital operation. Am I missing something here? Don't want to ruin the equipment. It is not installed as yet. Help!
Robert J P
Offline Maxi
#13 Posted : 21 May 2005 04:46:36(UTC)
Maxi
If memory serves me right the following photo shows what the underside of the carriage should look like if it was updated for digital operation.
If the underside looks like the following picture then most likely the unit needs to be sent in for conversion.
Edited by moderator 11 January 2011 16:28:15(UTC)  | Reason: Not specified
Offline robertrt
#14 Posted : 21 May 2005 06:54:26(UTC)
robertrt
Maxi
Thanks so much. My unit is as the first picture. Whew! That's a relief! You the man.
Robert J P
#15 Posted : 21 May 2005 15:44:26(UTC)
Thanks for seeing the picture,Did you make it or marklin service make it.
Offline Maxi
#16 Posted : 21 May 2005 15:59:42(UTC)
Maxi
I can not take credit for the pictures as the pictures originally came from a windigipet workshop document. The original intent of the document was to allow a fleishmann turntable to be connected to the 7687 digital module.
There was another document I found once on the internet which described the conversion of the marklin model but I can not find it anymore and I did not save a copy of it.
I also confirmed the pictures with my turntable and the modification is the same process. The only difference in mine was the location of the diodes. Diodes used were 1N4002 in case anyone was wondering.
Offline laalves
#17 Posted : 07 June 2005 16:08:14(UTC)
laalves
Maxi, I also have a Fleischmann version of the TT. Can you point me to that information to put it to work with the 7686?
Luis
Offline Maxi
#18 Posted : 07 June 2005 20:25:34(UTC)
Maxi
The document can be found here in German (Workshop #15)
http://www.windigipet.de/download4.html
If one were to become a member (free of charge) then the document can be found in english also. The section quoted above is no longer being maintained, there is more information in the forum section of the website.
Maxi
thanks 1 user liked this useful post by Maxi
CS3 with Turntable 7286 + 7687 (Digital)
by luckas 13/05/2021 14:36:55(UTC)
Turntable 7286/7686 with C-track (H0-scale)
by MartinS 27/05/2020 11:47:03(UTC)
turntable 7286 Marklin (Digital)
by springboard 15/11/2019 23:28:39(UTC)
Turntable 7286 & Decoder 7687 (General MRR)
by Drongo 24/10/2019 05:30:17(UTC)
Turntable 7286: How to modify the bridge to add more detection sections ? (Digital)
by French_Fabrice 02/10/2019 19:15:07(UTC)
Turntable 7286 (H0-scale)
by dennis 22/09/2017 21:06:52(UTC)
Turntable 7286 and CS3 (Digital)
by Twisterdodger 07/05/2017 14:51:28(UTC)
by twmarklinfan 14/10/2016 18:08:21(UTC)
Turntable 7286 with 7687 in CS2 Layout (Digital)
by dconstan 27/03/2015 19:34:44(UTC)
setup turnTable 7286 with cs2 (Digital)
by marklin-ho 27/08/2013 03:11:50(UTC)
Turntable 7286 motorconversion (Digital)
by sveni3 16/07/2013 19:26:00(UTC)
The turntable 7286 and Fleiscmann 6052 are the same? (H0-scale)
by akv2002 16/06/2012 03:08:24(UTC)
Question about turntable 7286 (H0-scale)
by arcanjo 10/06/2012 17:14:55(UTC)
Turntable 7286 & Rocrail : quick Howto (Model railroad software)
by French_Fabrice 16/05/2012 00:06:37(UTC)
transformer for Crossing 74920 and turntable 7286 ?? (General MRR)
by sop 02/08/2011 07:17:06(UTC)
Part numbers for Marklin turntable 7286 (H0-scale)
by Bryan 26/03/2011 05:24:45(UTC)
Anybody with the manual for turntable 7286 (H0-scale)
by Schienenbus 24/01/2010 08:29:56(UTC)
Turntable 7286 track power (H0-scale)
by Pavle 03/05/2008 20:09:30(UTC)
How to service Märklin Turntable 7286? (H0-scale)
by Voller 29/12/2007 13:14:34(UTC)
I have got the Marklin turntable 7286 (H0-scale)
by sebastian 23/10/2007 04:22:26(UTC)
Turntable 7286 (Digital)
by Adrian1 28/04/2007 02:09:58(UTC)
by vanDongen 22/12/2002 16:33:43(UTC)
This page was generated in 0.843 seconds.
