Offline biswasg
#1 Posted : 12 January 2009 07:44:17(UTC)
biswasg
Is there a Marklin 60880 substitute by Viessman or some other manufacturer which is fully compatible with the original?
Gautam
Offline Sander van Wijk
#2 Posted : 12 January 2009 10:19:27(UTC)
Sander van Wijk
Hi Gautam,
Sure there is, a commonly used substitute for the 60880 is Viessmanns 5217.
Sander
Offline prjbourge
#3 Posted : 12 January 2009 20:17:49(UTC)
prjbourge
Hi Cool
the Viessmann 5217 works fine (I operate it with a CS1 on the S88 bus), one thing you have to know is that is sold with a S88 cable which is very short, so it is advisable to order a longer cable as option.
Viessmann also sell Reed contacts which fit perfectly on C-gauge tracks and small magnets to be installed under the locs
Offline mjrallare
#4 Posted : 12 January 2009 23:16:10(UTC)
mjrallare
The reason for the short cable, and a way to change it to a longer one, can be found here:
http://www.viessmann-modell.com/pdf/hinweis.pdf
/Torbjörn
This page was generated in 0.462 seconds.
