Offline charles Sharpe
#1 Posted : 10 July 2008 23:38:11(UTC)
charles Sharpe
I must say I think Meaklin think we are mind readers. Please can you tell were do the two Blue wires go that comes with the piece of track sorry to be so thick.
CHARLES SHARPE
Offline dntower85
#2 Posted : 10 July 2008 23:46:04(UTC)
dntower85
As the pick up shoe crosses the contact on the top it makes a connection to the track current, which wire get the current is determined by the direction of travel. the wires can go to an S88 or even a signal in analog mode.
DT
#3 Posted : 10 July 2008 23:50:42(UTC)
charles Sharpe
Hi. dntower85. Can the wires go any were else. I am using the circuit tracks at each end of a shuttle train run.
CHARLES SHARPE
Offline Hoffmann
#4 Posted : 10 July 2008 23:53:57(UTC)
Hoffmann
Hello Charles,
Think of the blue wires as you seen them on the Turnouts. The contact Track works like this:
A brown wire from the Contact track is hooked up to the ground ( outer rail )one blue wire switches what ever you hooked up to it ( same as a 72720 )in one direction, the other blue wire is the same but for the other direction.
Did your Contact Track not come with Instruction ???
Martin
marklin-eh
Offline Hoffmann
#5 Posted : 10 July 2008 23:55:44(UTC)
Hoffmann
Me again Charles,
Are you using a 6600 for your shuttle operation???
martin
marklin-eh
#6 Posted : 11 July 2008 00:16:08(UTC)
charles Sharpe
Hello Hoffmann. Yes the track did come whit instructions but it just shows you the two blue wires attached to the 24194 but not were to connect the other ends.
I am sorry I do not know what a 6600 is.
CHARLES SHARPE
Offline Hoffmann
#7 Posted : 11 July 2008 02:39:25(UTC)
Hoffmann
Hi Charles,
Here it goes the Circuit track is simply a Microswitch (Toggle switch on/off) when the Locomotive slider runs over it, it switches to "on" momentarly. You can activate with this a Turnout or Signal etc. As I said it just acts like the button on the 72720 Controlbox. If you are using the Central Station to control your Train in Shuttle mode you need a Contact track (like the 24194 ) and a S88 Feedback Module which is connected to the Central Station.
This was all ready mentioned here on this Forum ( look up " help with shuttle trains-solved " ).
Martin
marklin-eh
This page was generated in 0.382 seconds.
