Offline monster134
#1 Posted : 14 May 2008 02:14:10(UTC)
monster134
Raait....i had a mystery on my hands here.A couple of months ago,i bought both 39010 and 2 39015's.Never really ran them,as i had a BR03 out a starter set that i normally tested with,and normally i used the class 10 37080 to check for clearances and so forth.
But,ive started my third board over the week-end,and i needed to build quite an incline to get to the sort of effect i need here.Nothing spectacular,but i did climb 20cm in 4 metres.biggrin
My measurements show the worst part of it to be around a 5% grade...With 18 coal hoppers behind it,my class 42.9 Franco pulls up there without spinning a wheel.The class 44's even easier.
Just to check i hooked the BR05 ahead of 6 lighted coaches,and it crawled up there without missing a beat.Same with my BR03.Went up no problem.
First BR01 i could lay my hands on was indeed 39010.Ive only run this once before,and i noticed then that it wasnt too bright a puller,and is very sensitive to slightly uneven track.Nothing motor wise,just had very little traction.
Anyways,long story short,neither the 39010 or any of the 39015's would pull my grade.Not even remotely.It wouldnt even go up there with 3 coaches....[:0][:0]
Ive ran my new 39103 a couple of times before,and made it a favourite.It could pull anything the BR05 did....and then some.Its indeed a pretty powerfull puller.Lots of traction,even over uneven track.
Hooked it up tonight,and you guessed it,flies up that incline like its not there.I even hooked 3 more coaches(no lights or extra shoe) behind the 6 original ones,and it pulled up there no problem.The first time it had a little wheelspin(still went over though) was when i hooked the track cleaner behind the coaches.
So....help me out here.They are basically the same locos right.39103 only has the oil tender.But a BR01 should be a BR01 right.....wrong.
So i thought it might be the tender giving 39103 more traction.It must be slightly heavier as it has an extra axle on there,but no way could i believe that.
So i carefully dissected them.Front bogie and drivers,excactly the same.BUT....the rear bogie on 39015 and 010 is 5mm longer than on 39103.
Also if you remove the bogies,the floor pan looks different on 015 compared to 103.
So,just for interest sake,i removed the rear bogie on 39010,and jip....it pulled up that grade with 9 coaches without spinning a wheel!!!!
And ive tried,you cant swop bogies,as the floorpan on 015 touches the wheels on the 103 bogie.
Even with its own bogie,i can see black marks where it touches the floor.All 3 of them have this problem.None of this on either of my 103's and my old 012.
So,i need to ask the question.Why change something that has been working for ages?And did they not test these things?The slightest little change in grade will make that rear bogie take weight of the rear traction wheel.And it just stands there and spins.Helluva frustrating.Is there a cure.I thought maybe slightly smaller wheels,but even with that the top of the bogie itself will touch the floor.
And to scale?Which one was right,or did they differ in real life too?
Im sure,if i remove the rear bogie on the BR45 i will find the same thing.That thing cant even pull itself...
If you look at the train form the side,even on the flats,that rear bogie runs very close to the floor of the cabin.Its just too long.
Your thoughts on this?
#2 Posted : 14 May 2008 03:01:28(UTC)
Unlike the 39010/15 which is powered by compact c-sine, the 39103 and 39104 are powered by the awesome older C-sine motors... They can probably climb a vertical wall and still pull a long henry load... I have yet to compare these with the new SDS, but in my opinion, the two things that Marklin really got right were m-track and the original C-sine motor... (and they did a pretty good job with the digital signals too)..
Good information about the bogies, but a good loco is the sum of its parts and not bits from another one...
Offline drwhitl
#3 Posted : 14 May 2008 04:24:24(UTC)
drwhitl
[size=1" face="Verdana" id="quote]quote:Originally posted by monster134
<br />So,just for interest sake,i removed the rear bogie on 39010,and jip....it pulled up that grade with 9 coaches without spinning a wheel!!!!
Look like you're in for some sort of modification to the rear truck to let it ride higher when it needs to. ....or you could try using a wheel of slightly smaller diameter in that truck. Just a mm or so probably wouldn't be noticeable visually, but it might make the world of difference to keeping the driving wheels on the ground.
cheers
Dennis
#4 Posted : 14 May 2008 10:46:17(UTC)
It sounds like it's at the change in grade that the problem occurs. Can you make the transition between flat and grade more gentle? That way you won't need to modify what is otherwise a beautiful model.
Offline monster134
#5 Posted : 14 May 2008 11:03:26(UTC)
monster134
Hi Ray....not neccessarily the transition.If i run that train on the flats,the actual space between the top of the bogie and the bottom of the floorpan is 1mm.Its over 3mm on 103.
Here are some of my ideas....either put a little spacer between the chassis and bogie so that it lifts the whole rearend up a bit.
Move the traction wheel to the front driver.
Even the smaller diameter wheel wont be enough,as its less then 0.5 of a mm difference between the top of the wheel and the top of the bogie.
Thirdly and as a last resort,maybe grind a couple of nanometersbiggrinof the actual floor of the cabin.
#6 Posted : 14 May 2008 11:20:03(UTC)
Views messages in topic : 15,542
<br />So....help me out here.They are basically the same locos right.39103 only has the oil tender.But a BR01 should be a BR01 right.....wrong.
A BR 01 is a BR 01 - and a BR 01.10 is a completely different story.
BR 01 is a two cylinder loco built for 130 km/h.
BR 01.10 is a three cylinder loco built for 150 km/h (originally they were streamlined).
So I think it's prototypical that the models do not share many parts.
M* indicates for many new models that you must not start grades in curves; you need straight tracks before the grade starts.
Could this be the problem?
Offline monster134
#7 Posted : 14 May 2008 16:43:26(UTC)
monster134
[size=1" face="Verdana" id="quote]quote:Originally posted by h-zero
<br />Hi!
I still dont get it.As far as im aware,39010 and 015 were the later BR01's with the 1m diameter wheels.They also had the longer thinner boiler.There is physically very little difference between the locos.
I mean,the BR03 resembles the BR01.10 design very closely on the rear bogie.
I had a look at a friend's BR01 from another make,and it has not got this problem.That rear bogie MUST NOT bottom out.
I have no inclines that start in the corners.
Even a slight dip on a straight will stop it momentarily.
Be that as it may,if i had known that i would need to be a bloody perfectionist,and run these locos on flat track only,i wouldnt even have bothered to buy it.It renders it useless to me.
Offline dntower85
#8 Posted : 14 May 2008 17:12:22(UTC)
dntower85
I had to make some adjustments to the track in order for my BR01 to not get stuck, it such a nice model I haven't wanted to modify the rear bogie on mine but I was thinking if i could find a set of wheels that looked similar but had a little smaller diameter I might swap them out. Or if i could get another set of wheels I might try to turn them down on a lathe.
DT
#9 Posted : 14 May 2008 17:23:08(UTC)
You obviously have a real problem with this, and I'm surprised that no-one else has reported the same. Having invested in 3 of these locos, you need some kind of solution.
Of your suggestions, I would try swapping the front and rear wheel sets, so that the traction tyres are on the front end. I have an old Br38 (3098), which came with this arrangement. In that case, the motor was mounted very far forward, so the traction tyres needed to be at the front because that is where the centre of gravity was. This might work for you.
Offline Hemmerich
#10 Posted : 14 May 2008 18:26:41(UTC)
Hemmerich
<br />It sounds like it's at the change in grade that the problem occurs. Can you make the transition between flat and grade more gentle? That way you won't need to modify what is otherwise a beautiful model.
Indeed. On my layouts I usually have no more than 3% grade. So I just did a quick setup (360cm/18cm=5%) and test with my BR01; surely with the appropriate change in the grade transition (0/0,5cm/1,5cm...). The grade even starts in a curve (R3). The loco easily pulled 9+ long coach cars up that hill, regardless of the selected speed (min/max) or function.
http://www.myvideo.de/watch/4186895
IMHO there is no need to modify anything with that loco, neither with the BR45 or BR05; the space between the front/rear bogies and the frame is fully sufficient for every "normal" built grade.
It might just be useful to check the front and rear bogie spring tension.
PS: I repeated the grade transition and pulling test now with some other models which are also partly mentioned here:
BR01.10 (#37101) - no pulling problem at all, crawling up the grade easily
BR05 (#39050) - no pulling problem at all, crawling up the grade easily
BR64 (#39640) - no pulling problem at all, crawling up the grade easily (only being pulled back down by 12+ cars, but wheels blocked) Cool
BR45 (#37450) - no pulling problem at all, crawling up the grade easily (only starts to roll back down with 10+ long coach cars)
Württ. C (#3611; converted with decoder from K) - no pulling problem at all, crawling up the grade easily (only starts to roll back down with 3+ long coach cars or 6+ 4axle Württ. coach cars)
#11 Posted : 14 May 2008 18:41:41(UTC)
as Lutz says, it is probably more top do with the rate at which your grade changes.
If you place the loco on a 10% slope that is straight, the relationship between the wheels and the chassis should be the same as when it is on horizontal track.
Offline monster134
#12 Posted : 14 May 2008 19:34:01(UTC)
monster134
No definitely,nothing wrong with its motor,as ive said before,i just think its a bad design.
Ive just measured a dip in my track where it gets stuck with a degree wheel ive got here.Its less than 1 degree out.
Thats a very fine margin.
Ive checked the BR45,and it has excactly the same design bogie.I took it off,and it pulls like a steamtrain......
I was supposed to take delivery of a class 41 2-8-2 tomorrow.If that is going to have the same problem....it stays at the shop,thats for sure.
Right....so anybody has any new 39103's lying around.I will swap right now.sh-tty sound or not,its just a better train.
Gmff,so you make your coaches shorter to benefit your clientele with small layouts,but in the same breath you build trains that are useless on anyhting but perfect track...
As a sidenote,ive slightly altered the track with toothpicks under the rail,and ive sorted most of the problems.When i screw the tracks down,i just need to make sure i dont tighten 1 single one more than excactly flush with the board.It will get stuck there.
Irritates the crap out of me.Turns a 3 day job into a 10 day job.[:(!]
#13 Posted : 14 May 2008 21:27:33(UTC)
Yes it can be frustrating, but the basis of good running (even on real railways), is well laid track.
Offline Hemmerich
#14 Posted : 14 May 2008 22:55:16(UTC)
Hemmerich
<br />...but the basis of good running (even on real railways), is well laid track.
How true!
I just tested it once more: going from 0 - 3 - 7,5 - 12 - 15mm by 2-1/2 straight tracks appears to be an almost ideal transition for a 5% grade. wink
(sorry, there was a typo).
Offline dntower85
#15 Posted : 14 May 2008 23:05:04(UTC)
dntower85
I place a few pieces of card stock under some section and moved piece of track and tightened a few screws.
what was making mine get stuck was the at a section of R1 track with a circuit track and a half section of R1. Each transition was small but just enough to stop the train. Also it just begs to go slow do to the fact that it runs so good at slow speeds Smile so it never has the momentum to get past the bump.
I don't think you can adjust the rear bogie much as the wheel might contact the bottom of the fame.
DT
Offline hmsfix
#16 Posted : 15 May 2008 02:23:21(UTC)
hmsfix
<br />No definitely,nothing wrong with its motor,as ive said before,i just think its a bad design.
Hi Riekus,
Few years ago I have had the same experience as you. I have always been used to the qualities of my old steamers from the 1960's and 70's, such as the BR 44 (#3047) or the S3/6 (#3092). These great locos "eat" every bump and grade transition of the tracks without the faintest problem.
After almost three decades of absence from the mrr hobby, when I got my US locos (Mikado, GG1) I realized that I was in a completely new mrr age. The mikado (which is a construction quite similar to M*'s recent BR 41 model) refused even to pass the next turnout, and I had to insert a lot of tooth picks and cardbord strips under my wiggly old M-tracks [:I]. That's the price to pay for a much more prototypical look and the more correctly scaled details of the new stuff.
On my new layout I had a simple way out: no screws on the tracks any more. Instead, I have fastened them with adhesives. If you are modelling your layout using a soft underground (e.g. styrofoam, as I do), the screws may cause small but nasty wiggles on the track, and on closer inspection the grade transitions are anything else but smooth. In contrast, on tracks fixed with glue there is much less bending stress, and I have never had any traction problems with my locos. And it's a relatively fast method (OK, it takes a few hours for the white glue to get hard)
Hans Martin
Offline DTaylor91
#17 Posted : 15 May 2008 02:45:51(UTC)
DTaylor91
[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz
<br />as Lutz says, it is probably more top do with the rate at which your grade changes.
I hope everyone doesn't miss the important point here being made by Dale and Lutz, as it may escape notice from those not more familiar with prototype railway practice.
Almost every real curve on a railroad has an "easement" into and out of the curve. Most model curves are of a fixed radius. Put another way, model curves tend to be and arc, i.e., circular. Prototype curves tend to be more parabolic, i.e., the radius of the curve gradually increases toward the apex of the curve.
If this still doesn't make sense (and trust me, I RARELY make sense), picture this:
Using C-track (for example), you could lay down a curve using all R3 track sections coming off the straight. Obviously, this would be circular, and have no easement at all.
Now instead, you come off the straight using an R5, then an R4, then an R3, then and R2, and then reverse the order coming back out of the curve. This would be a much more parabolic curve, and have easements into and out of the curve.
Now, a lot of people know this, but the BIG POINT is, all the above is working in the horizontal plane. Easements need to be created in the vertical plane as well!
How to do it with C-track? Not sure, but possibly starting with shorter-length sections and gradually increasing length as the grade is established will give enough flexibility to do this.
To my way of thinking, with people asking for "flexible" C-Track, it would be much better to have a piece of C-Track that's flexible in the vertical plane as opposed to the horizontal plane.
K-Track guys have it made, in a sense. They just need to be much pickier in laying out their track, because they will have to adjust everything, and lay everything out from an approach much akin to what a real railroad surveyor would have to do. I'm sure a lot of guys would enjoy that. Me, I'd go crazy, and I'd much rather be building models and running trains! Smile
DT
Offline Hemmerich
#18 Posted : 15 May 2008 02:54:28(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by dntower85
Hi Darrin, Rieker, et al,
part #344420 should solve your problem. wink
#19 Posted : 15 May 2008 15:13:57(UTC)
Very interessting and good write-up, Riekus! -Thanks!
Offline Hobbit
#20 Posted : 16 May 2008 06:55:05(UTC)
Hobbit
@Lutz, I would love to see a photo comparing #344420 and #219505 (which the original part for 37452) if that is not too much trouble. Which locomotive(s)does #344420 normaly belong to?
There is no place like The Shire...
Offline Hemmerich
#21 Posted : 16 May 2008 14:09:18(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by Hobbit
<br />@Lutz, I would love to see a photo comparing #344420 and #219505 (which the original part for 37452) if that is not too much trouble. Which locomotive(s)does #344420 normaly belong to?
to this beauty here: [:p]
#37115, see attached picture (wheelset on the right; left is from BR01). wink
PS: The part# you listed above for the BR45 (#37452) contains the complete rear bogie and the wheelset, which has part #104453 and is the same for the BR01 (#39010 etc).
Measures #344420 vs. #104453:
wheel track diameter: 13,8mm - 14,0mm
overall wheel diameter: 16,4mm - 16,8mm
This diameter difference will allow the rear bogie to move across most usual "bumps" and grade transitions w/o touching the loco bottom. The only suitable additional action (besides replacing the wheelset, which is really easy) would be to paint the axle of the new wheelset as well red.
PS: The wheelset on this picture shows the one from the first Württ. C version #3611; the current one from #37115 is a slightly darker red. Another alternative would be to just reduce the outer wheel diameter (wheel flange) of the original wheel set. I checked with the Märklin repair service and got confirmation that they have not seen any such complaint from customers. They also told me that the wheel size differences which I had measured is still within the production tolerances for these parts.
Offline dntower85
#22 Posted : 16 May 2008 17:45:28(UTC)
dntower85
Lutz, Thanks for the info,Cool if I ever come across those wheels I get them.
All though its much easer just to adjust the track wink
DT
Offline Hobbit
#23 Posted : 18 May 2008 18:02:50(UTC)
Hobbit
Very interesting Lutz. So if I understand correctly the bogies are the same but the wheel sets are different. However, could you please clarify the part numbers; in your post of 15.5.08 you say 344420, and in your post of 16.5.08 you say 344440.
Actually, on closer examination of the exploded parts lists for 37450 and 37452 they both seem to have the same bogie #219505, but the 37450 has wheelset #343480 while 37452 has wheelset #104453.
I wonder if the wheelset #343480 is smaller than #104453, which might explain the differenc in performance between the two? Or perhaps it is in the other wheels as both models have different part numbers for all the wheels?
Offline Hemmerich
#24 Posted : 18 May 2008 23:58:18(UTC)
Hemmerich
<br />Very interesting Lutz. So if I understand correctly the bogies are the same but the wheel sets are different. However, could you please clarify the part numbers; in your post of 15.5.08 you say 344420, and in your post of 16.5.08 you say 344440.
Sorry for the typo - #344420 is the correct one (I changed it in the posting above)
[size=1" face="Verdana" id="quote]quote:Actually, on closer examination of the exploded parts lists for 37450 and 37452 they both seem to have the same bogie #219505, but the 37450 has wheelset #343480 while 37452 has wheelset #104453.
The bogie is the same, but does not require to contain the same wheelset.
[size=1" face="Verdana" id="quote]quote:I wonder if the wheelset #343480 is smaller than #104453, which might explain the differenc in performance between the two? Or perhaps it is in the other wheels as both models have different part numbers for all the wheels?
The only difference between the two wheelset numbers is the painted axle; they both have a wheel diameter of 14/16,8mm. wink
I'm just waiting for the delivery of a new wheelset #344420 and will let you know if it has different metrics than those measured for the same wheelset on on my Württ. C. #3611 (13,8/16,4mm).
Offline monster134
#25 Posted : 25 May 2008 16:27:59(UTC)
monster134
I went through great trouble,and switched the rear bogie's wheels with that from my little Class C.
Its still not enough.If i put the smaller wheel from the BR05 in there(thinner axle,so it cant be used)it will pull anything no problem.
Now,ive looked at technical drawings of both BR01.10 and the normal BR01...and yes,both locomotives had a 3.8m span from the middle of the rear driver to the middle of the rear bogie wheel.
So why the hell have they given 39010 and 39015 a longer bogie????
Offline monster134
#26 Posted : 25 May 2008 16:42:51(UTC)
monster134
<br />I went through great trouble,and switched the rear bogie's wheels with that from my little Class C.
Actually,ive measured the bogies with a vernier,and 39103 has a 39,85mm span at the rear,and 39010 and 015 has a 43.67mm span.
Which makes the 39010 and 015 prototypically correct.
Pity on the model railroads of this world...it renders the thing useless.
Ive checked the maximum amount of travel in that rear bogie,and it allows for a maximum deviation in actual rail of 0,89 of a degree....
Thats some pretty small tolerances.Only way i see to rectify this is to swap the front driver out for one with a traction wheel as well.
Its very easy to see that smaller rear wheel.Not worth it imo.
This page was generated in 0.921 seconds.
