Offline Mjn2ts
#1 Posted : 31 March 2025 23:57:28(UTC)
Mjn2ts
Views messages in topic : 56
I'm having a hard time trying to understand how to determine what resistor I need to use in a locomotive that I'm converting to led lights. In the documentation for the decoder there is no "supply voltage" listed, only "Current load at the light outputs" and that says less than 250 milliamps then there is "maximum voltage" and that says less than 40 volts. I'm not sure what to use for the "supply Voltage". Its a Marklin 60977 decoder if that helps. The info for the led was pretty straight forward:
Luminous Intensity: 1560/2180mcd
Forward Voltage: 2.1/3.1V
Viewing Angle: 30°
Minimum Operating Temp: -30°C
Forward Current: 30mA
Reverse Voltage: 5V
Wavelength: 624/6500nm
#2 Posted : 01 April 2025 07:59:58(UTC)
The slash "/" makes me think that the chart contains data for two different types of LEDs.
Do not go beyond 20 mA. Modern LEDs are typically bright enough at 2 mA or even less.
The output voltage of the decoder is input voltage minus the voltage drop inside (rectifier, output transistors). Assume 24 V
LEDs should still be very bright with a 10 kOhm resistor and can be dimmed further using decoder programming.
Offline Mjn2ts
#3 Posted : 01 April 2025 10:29:25(UTC)
Mjn2ts
It is 2 different leds in one, they are red/white with 3 prongs. While searching I came across an older post that seemed to indicate that the supply voltage was basically track voltage or the output of the controller, so roughly 19volts. If I assume your 20mA is accurate that would put my resistor at around 805ohms. I think...
thanks 1 user liked this useful post by Mjn2ts
#4 Posted : 01 April 2025 12:13:53(UTC)
It's around 19 V for a CS3, but around 22 V for a CS2 with a transformer and around 23 V for a 6021.
When you do the maths for 24 V your pretty good on the safe side.
I made conversions where I have three white LEDs in series. There was a 1k5 resistor on the decoder board, but I added 20k and the light was still on the bright side.
You can easily test the LEDs with a bridge rectifier and different resistors (10k is a good start) to see how bright they are.
#5 Posted : 01 April 2025 21:43:01(UTC)
20mA is the maximum safe current for an LED, but if you run them at that you will burn your eyes out. I would use a resistor of 8.2k or 10k as suggested by H0 as a starting point, and I think you will find they are plenty bright at that current.
Offline Mjn2ts
#6 Posted : 01 April 2025 23:11:51(UTC)
Mjn2ts
Think I'm gonna end up using the 8.2k, it was bright but not too bright and I can always turn it down in the decoder settings. Still not sure how that works, the online calculator I found is saying 800-1000.. Thanks for the guidance!! Jeff
#7 Posted : 02 April 2025 08:01:55(UTC)
The calculator finds the value for 20 mA, but 2 mA already give very bright light.
Trust the calculator if you want to build a desktop lamp, but use bigger values for locomotives.
P.S.: Dimming the LED with the decoder will lead to high-frequency flickering that might become visible when filming, therefore it makes sense to increase the resistor value.
Offline Mjn2ts
#8 Posted : 02 April 2025 10:18:52(UTC)
Mjn2ts
Thanks for the help!! Jeff
This page was generated in 0.463 seconds.
