Offline rickjames84
#1 Posted : 16 February 2025 13:25:28(UTC)
rickjames84
I am currently using railroad modeller to design my my first layout, I had some suggestions from other user to put a reverse loop, I been trying to plan one out but im stuck. I would appreciate any assistance and I can send me layout file also.
Thanks in advance,
Rick.
#2 Posted : 16 February 2025 14:29:08(UTC)
Hi Rick
You don't say what system you are using.
In 3 rails (Märklin HO) it is the easiest thing: only find the correct geometry
I suggest you make your selection from these plans by Märklin
Märklin free track plans
Another possibility is to use track plan sofware (I use Wintrack)
Remember that these software can be used FOR FREE if you don't store the plan file. You may always make a screen copy of your track figure
Here is an example using C Track and Wintrack
Last, you have the old way: have plenty of tracks of various lengths and radii and make the figure you want
Offline rickjames84
#3 Posted : 16 February 2025 15:02:03(UTC)
rickjames84
Hi Rick
Thanks for the reply, I am using Railroad modeller Pro and Marklin Tracks
I have included a sample of what I am working on.
Offline rbw993
#4 Posted : 16 February 2025 15:09:34(UTC)
rbw993
Hi Rick,
Something to consider - It looks like you have sufficient room to get rid of R1 curves on the main line. Using R2 and R3 will allow the trains to "flow" better around the curves.
Roger
Offline rhfil
#5 Posted : 16 February 2025 15:16:43(UTC)
rhfil
You have been a member since:: 05/09/2014(UTC)
If your consists are short and you have the room you can also use a wye to reverse. All you need is a three way switch. Unfortunately it appears your short sections are too short for a wye or a reverse loop.
Offline rickjames84
#6 Posted : 16 February 2025 15:28:36(UTC)
rickjames84
What is a wye? I am new to the hobby and still learning.
Offline rickjames84
#7 Posted : 16 February 2025 15:33:03(UTC)
rickjames84
Hi Rick,
Roger
I am very limited on room and size reasoning for the R1 curves, I used a Marklin sample diagram and just added few extra tracks I had.
Offline hermanvk
#8 Posted : 16 February 2025 15:41:03(UTC)
hermanvk
You have been a member since:: 15/11/2023(UTC)
a wye turnout
thanks 1 user liked this useful post by hermanvk
Offline rickjames84
#9 Posted : 16 February 2025 15:52:36(UTC)
rickjames84
a wye turnout
Thank you very much!!!
Offline ccranium
#10 Posted : 16 February 2025 19:25:54(UTC)
ccranium
Hi Rick,
I'm not a C-track nor Wintrack user, but could you put a reversing loop in the upper right part of your layout behind the station, at least for the inner mainline? And the same for the other main line in the upper left area?
Brian
Offline rbw993
#11 Posted : 16 February 2025 21:57:05(UTC)
rbw993
Hi Rick,
Roger
The r2 and r3 curves won't make the layout any larger, the straight sections will be shortened.
Roger
Guest (6)
If David Copperfield were a railroad modeller (Painting & Weathering)
by usta 07/01/2009 20:34:24(UTC)
This page was generated in 3.777 seconds.
