Offline garben
#1 Posted : 21 January 2025 01:24:36(UTC)
garben
Hello.
It seems that after a few years my c-track layout has probably “shifted” a bit. I’m seeing a few places where the rails are touching ever so slightly thus loosing the isolation. The connection under the track is fine, I use the small red isolators and cut the connectors under the c-track.
I was wondering if anyone has any suggestions, tips, techniques to prevent this. I screw down my track and ballast it so when this happens it takes a bit of work to fix.
Thanks!
thanks 1 user liked this useful post by garben
#2 Posted : 21 January 2025 03:23:42(UTC)
Yes Garben, with expansion and contraction tracks can shift, much in the same way as life-size tracks do.
Offline LeoArietis
#3 Posted : 21 January 2025 08:33:31(UTC)
LeoArietis
Views messages in topic : 206
Some paint or add a tiny droplet of hot glue in between the rail joint. You may also grind the rail a bit shorter.
Current layout:
The former project:
thanks 1 user liked this useful post by LeoArietis
Offline rbw993
#4 Posted : 21 January 2025 14:18:02(UTC)
rbw993
You can widen the rail gap with a fine hacksaw blade clamped in a vise grip pliers. This can be done in place. Be sure to vacuum up the metal dust after. One of the small hobby saws may work also but many aren't sufficiently hardened, fine for plastic but not metal.
Roger
#5 Posted : 21 January 2025 15:11:19(UTC)
Hi Garben
The issue you mention is caused by a plastic retractation during the aging: the plastic shrinks and the initial spacing of rail reduces.
When starting a ramp upwards especially the rails may come in contact even if they are insulated.
What to do?
- remove the rail where insulated rail starts and file the rail extremity to extand the gap
- force the rails apart and insert a tiny piece of nylon and glue it in place
- use a disk (Diamond or a plain cutting disk). Drawback: the cut is wide (just below a mm) and it leaves a lot of conducting dust that must be removed with a vacuum cleaner.
On K track, rail sliding is much more common and gaps must be filled with glue
On C track, I never observed a rail sliding lengthwise
Offline Kiko
#6 Posted : 21 January 2025 16:59:17(UTC)
Kiko
Hello Garben,
One suggestion that seems to be less intrusive than glue (or hot glue) is inserting a tiny piece of plastic between the two rail ends. I use a piece of flat stock styrene, which I cut into a tiny square and push it between the rails with small tweezers. It's a tight fit and will stay in place even with small expansions/contractions of the layout.
Andry
thanks 2 users liked this useful post by Kiko
This page was generated in 0.431 seconds.
