#1 Posted : 26 November 2024 15:04:33(UTC)
It only occurs at this spot, more so when running two or more trains. It's about 5.5 metres from the CS3 power feed connection point. Trains also pause there at slower speeds, especially until they warm up. I have about a total of 20 metres of C track maximum.
Note; This is also where my JC ski lift power feed connection from the track is. It doesn't matter if it is on or not, and it never stalls.
Thank's in advance everyone!
Online JohnjeanB
#2 Posted : 26 November 2024 15:16:30(UTC)
I am not a specialist or anything but I noticed that:
- when there are pick-up issues (a loco that has not been used for a while), the sound may come off for a while (a few seconds most of the time)
- 5.5 meters from the power feed seems a lot to me
- specialist recommend a power feed every 2 m of track (good new C track) or even more often with M track or K track where rail joiners may cause a problem
- with C track, the key issues are: rails may be covered with non-visible "machin" causing poor mass return, the studs are with soft iron so prone to corrosion (like M and K Tracks)
I know some specialists will object / scream but I use gade 2000 or finer (Garde 5000) abrasive paper (used with water in the body work industry in the paint finish job) Of course for trains, used without water. The grain is so small that it polishes the rail and studs and removes the "goey" on rails.
#3 Posted : 26 November 2024 15:47:40(UTC)
Oh, many thank's Jean! I did rub my fingers over that track section, as I didn't see any shmutz. My trains were idle in the main station quite a while.
This page was generated in 0.282 seconds.
