Offline Vernon Adams
#1 Posted : 01 November 2024 15:23:17(UTC)
Vernon Adams
I have received a Lima wagon which has metal wheels. My question is, are these wheels going to short circuit on my Marklin C track
Thanks in advance
Vernon
thanks 1 user liked this useful post by Vernon Adams
#2 Posted : 01 November 2024 16:02:59(UTC)
No they won't because one wheel is insulated. However, if you have any 3 rail contact tracks, they won't complete the circuit. Unless someone else has changed the wheel sets to uninsulated, that is. You can tell by a small disc on one inner axle/wheel.
Offline TrainIride
#3 Posted : 01 November 2024 16:05:32(UTC)
TrainIride
Hi Vernon,
No problem with metal wheels, since all Märklin wagons have had metal wheels for a very long time.
Do you already have a few Märklin wagons ? You will see they're all metal wheels.
Märklin C track is a three-rails AC system with both rails at the same electrical potential.
So Märklin wagons have non-insulated wheels.
In principle, Lima wagons have the wheels isolated from each other to be able to run on two-rails DC systems.
So no short circuit problem when running a two-rails DC wagon on a Märklin three-rails AC track.
One small difference between Märklin wagons and other two-rails DC brands is the wheel spacing on an axle.
13.8mm for Märklin
14.3mm for two-rails DC wagons.
This can cause derailments sometime when passing over the switches.
I hope I answered your question.
Best Regards
Joël
thanks 2 users liked this useful post by TrainIride
#4 Posted : 01 November 2024 16:16:21(UTC)
Vernon Adams
You certainly have Joël. I certainly appreciate you quick reply.
Thank you so much
V
thanks 2 users liked this useful post by Vernon Adams
#5 Posted : 01 November 2024 16:24:21(UTC)
True, also with some Roco cars, but even some Marklin cars derail in C turnouts.
This page was generated in 0.674 seconds.
