Offline Marklin Nut
#1 Posted : 12 October 2024 22:44:17(UTC)
Marklin Nut
Hello all,
Has anyone successfully installed the Marklin Link s88 with using the diode trick in a layout that has a combination of C track and K track? If so, how should the common ground be wired when transitioning between K track and C track?
On both the C & K tracks, one rail is the common ground while the other rail is the insulated contact rail that's wired to the Link s88. A diode 1N1400x spans between both rails with the ground flow (arrow) pointing towards the insulated rail.
In a test, the isolated contact tracks worked with the diode trick but when the locomotive entered from the K track into the C track, a short became present. No common ground wires are connected to the C track, only the K track.
Do I need to connect a brown wire to the common side of the C track rail to eliminate this problem?
Thank you,
Offline PeFu
#2 Posted : 13 October 2024 13:40:49(UTC)
PeFu
It sounds to me as if you by mistake have connected the diode from the isolated rail on the C track, to ”red” and not to common ground?
Offline Marklin Nut
#3 Posted : 13 October 2024 15:05:17(UTC)
Marklin Nut
Thank you for the advice, I will go and check my diode connections. It makes sense. When the CS2 is in stop mode, all sensors are working correctly but when I turn the CS2 to go, a short occurs. I'll keep you posted what my investigation finds.
Thanks again for your quick response.
Offline Marklin Nut
#4 Posted : 28 October 2024 01:02:58(UTC)
Marklin Nut
I'm providing an update to anyone who is following this post.
After checking my diode connections, I found all to be wired correctly. The problem was a very small piece of loose solder stuck between the O-(Isolated Ground) and the B-(Bahn) channels that connect to the matting part of the joining C-track section. After removing this piece of solder, everything worked as expected.
The occupation feedback signal was a clear "on" and "off", the diode trick really works well. BigGrin
A big thanks to all who posted a reply and past posts on this topic.
This page was generated in 0.252 seconds.
