Offline Kiko
#1 Posted : 25 March 2023 22:52:53(UTC)
Kiko
Hello Everyone,
Has anyone had any luck with the following:
1. Wagon (car) fitted with ESU Digital Lighting Kit (50708)
2. Marklin loco with MFX+ decoder.
I'm trying to activate the 50708 in TrainController Gold when the car is attached to an MFX+ loco. It works fine if the car is attached to a loco with LokSound decoder and I can also activate the lights in the car stand-alone (short or long address). Note that I have configured the 50708 decoder as "Alternate Address" in both locos (see pictures). Somehow, the loco with MFX+ decoder does not relay that function to the 50708 decoder in the car.
I've tried setting the 50708 with "short address" and "long address" with no luck. The exact same scenario works great with a loco fitted with a LokSound decoder. (Pictures attached showing both function key assignment in LokSound equipped loco and MFX+ equipped loco).
Any help would be much appreciated. Confused
Andry
#2 Posted : 27 March 2023 06:21:18(UTC)
Views messages in topic : 9,358
There is no mfx protocol in ESU digital light. Just only MM and DCC.
Offline PeFu
#3 Posted : 27 March 2023 07:13:53(UTC)
PeFu
The ”Alternate Address” feature in TrainController requires that the engine decoder and the function decoder (your light decoder) use the same protocol. I have sent a request to Mr. Freiwald on this earlier. I guess we Märklinists are a bit ”special” in the MR world, not dealing with DCC only…
I haven’t found any other way to automatically trigger function decoders when the train is running.
RollEyes
Offline Kiko
#4 Posted : 27 March 2023 16:28:45(UTC)
Kiko
Hello "Goofy"
Thank you for that info. I kind of figured as much after playing around with the 50708 and both LokSound and MFX locos.
Hello "PeFu",
Thank you very much for that info -- now it's clear to me. I have replaced the MFX+ loco with one that has a LokSound decoder in it and everything works great. As you said, we "Marklinists" _are_ a bit different! BigGrin I, too, run multi-protocol locos (ESU and Marklin). I only have Marklin locos and have converted to LokSound only those that had the old decoders or any that did not run so well. I'm very happy with the combination.
Once again, thanks for the reply.
Andry
Andry
thanks 1 user liked this useful post by Kiko
This page was generated in 0.306 seconds.
