Offline Marklineisenbahn
#1 Posted : 29 September 2022 19:28:56(UTC)
Marklineisenbahn
Hallo Dreileiters,
Good news from Märklin GmBh! New surprise steam locomotive
from Slovakia 🇸🇰! Albatross Class 498.1 heavy express train steam locomotive with a tender. Version as museum locomotive road number 498.104 of the Železnice Slovenskej Republiky (ŽSR) / Slovak Republic Railways. The locomotive looks as it currently does in real life, i.e. as the operational locomotive currently based in Bratislava.
The locomotive model has an mfx+ decoder and extensive light and sound functions. It also has controlled high-efficiency propulsion with a flywheel, mounted in the boiler. 4 axles powered. Traction tires. The locomotive and tender are constructed mostly of metal. The locomotive also has a factory-installed smoke unit with speed-dependent, dynamic smoke exhaust. The locomotive has triple headlights and the tender has dual headlights. These lights change over with the direction of travel and can be controlled digitally. The upper headlight on the locomotive can be controlled separately. There is a working lighted locomotive number board built into the upper headlight. The cab lighting can be controlled digitally. Maintenance-free warm white LEDs are used for lighting. There is an adjustable close coupling with a guide mechanism between the locomotive and tender. There is a close coupler with a guide mechanism and an NEM pocket on the back of the tender. The buffer height on the locomotive and the tender adheres to NEM standards. Brake hoses, imitation prototype couplers, and an air tank for installation on the tender are included. Piston rod protection sleeves are also included. The minimum radius for operation is R2=437.5 mm / 17-1/4".
Length over the buffers approximately 29.3 cm / 11-1/2".
Top Highlights:
Completely new tooling!!!
Especially intricate metal construction.
Many separately applied details.
Factory-installed smoke unit with speed-dependent, dynamic smoke exhaust.
Cab lighting can be controlled digitally.
World of Operation mfx+ digital decoder and extensive sound and light functions included.
Buffer height on the locomotive and the tender adheres to NEM standards.
This model can be found in a DC version in the Trix H0 DCC assortment under item number 25498.
As per Mrs.Cousins will be Available in US in few weeks… 🤔🤪
Link below:
https://www.maerklin.de/.../big-surprise-model-2022
Märklineisenbahn
thanks 1 user liked this useful post by Marklineisenbahn
#2 Posted : 29 September 2022 20:21:03(UTC)
Guest (4)
This page was generated in 0.231 seconds.
