Offline Mr. Ron
#1 Posted : 08 September 2022 05:55:04(UTC)
Mr. Ron
Why are there so many "S" curves on European model railways? Are the real railways so curvy? The model trains, especially long passenger cars take on a "snake" like appearance when going around S curves.
#2 Posted : 08 September 2022 08:05:12(UTC)
Are there "many" "S" curves? On all layouts? On many? On some?
If a railway line follows a river valley, there will be all sorts of curves.
If you have a double track and need room for a platform, there will be S curves.
If there is anything you have to avoid - a rock, a town, a city, a river, a hill - then you will need a curve or maybe an S-shaped curve.
Temporary S curves caused by construction works:
https://www.bing.com/map...amp;lvl=16.8&style=a
Offline Copenhagen
#3 Posted : 08 September 2022 11:32:27(UTC)
Copenhagen
I think it's mostly a space related issue. We often want to squeeze in as much track as possible. Using R3, 4 and 5 curves would look nicer but they take up a lot of space.
thanks 2 users liked this useful post by Copenhagen
Offline Toosmall
#4 Posted : 08 September 2022 12:17:11(UTC)
Toosmall
Australia has a lot of straight track, but if you would like to model some S bends. Google the railway line both east and west of Katoomba in the Blue Mountains west of Sydney. I have been on it a few times, once on the Indian Pacific train, and it snakes through the landscape, along the top edge of a narrow river gorge and 10 tunnels from memory.
https://en.m.wikipedia.o...wiki/Blue_Mountains_Line
'The Blue Mountains line is a section of the Main Western line which opened in 1868. The line was built with gradients as steep as 1 in 33 (3%) and curves as sharp as 8 chains (160m). Most of the curves were eased to 12 chains (240m) with duplication.'
#5 Posted : 08 September 2022 13:56:49(UTC)
No there are no curves in modern European railway lines. In the old days, they were a succession of straight and curved sections. Now it is about parabolic connections. Now the TGV lines have often radii above 6 km and straight lines streches above 40 km are not so rare (it depends on the population density) but this is not matching the old-style train landscape cliché of trains following a valley, a river (like the rail lines along the Rhine). European modelists like this "old-style train landscape"
#6 Posted : 08 September 2022 14:09:30(UTC)
Good to know.
Offline Toosmall
#7 Posted : 08 September 2022 15:08:03(UTC)
Toosmall
Even I would find Australia's longest section of straight track modeled in Z gauge a little bit tedious at 2172 metres!
#8 Posted : 08 September 2022 19:41:30(UTC)
Views messages in topic : 8,633
BigGrin BigGrin BigGrin Even more tedious if it was to travel it at the scale speed of the real train - it doesn't get that fast, only about 40-50kph maximum as I recall.
Offline Toosmall
#9 Posted : 08 September 2022 20:06:15(UTC)
Toosmall
Not as tedious at having to walk to the other end (one hour return) of your 2172 metre layout because the train stopped for some unknown reason, wishing you put in some bloody S bends!
I think I have about 32 metres of main lines on my layout but 2.7 metres is a long enough walk for me!
Main line fly through:
Flythrough.mov (1,380kb) downloaded 128 time(s).
Offline PeFu
#10 Posted : 09 September 2022 07:38:33(UTC)
PeFu
Gotthard Bahn
Above, the Wassen section of the old double-track Gotthard Bahn. ThumpUp
Elevation is also a major reason for S-curves here, as well as rivers, lakes, valleys, hills, villages and cities. Sometimes, even the search for better ground (geology) could be the reason. But I agree, newer high-speed lines tend to run over, through or under these obstacles.
Smile
thanks 4 users liked this useful post by PeFu
Offline Mr. Ron
#11 Posted : 12 September 2022 19:51:38(UTC)
Mr. Ron
I looked at a Google map of Germany, specifically around Hamburg nad could not find any examples of "S" curves. Curves were very gradual. I suspect the reason for tight "S" curves is to suit model layouts and their space availability. The really big layouts, like Miniatur Wunderland and Dr. Porches' have the room for gradual curves.
#12 Posted : 12 September 2022 20:22:28(UTC)
How about this snippet from Hamburg, the line heading north by northwest:
https://www.google.de/maps/@53.4606199,9.9871927,1129m/data=!3m1!1e3?hl=en-GB
Of course, radii are much larger than the R5 or even R9 we have with C track.
#13 Posted : 12 September 2022 23:31:09(UTC)
I don't think anyone is silly enough to believe that model trains are anything other than a compromise in regards to scale.
It is unrealistic to think otherwise.
The early railway builders were smart enough to build curves that would allow unimpeded travel of their flanged wheels (or wheel types that were in use) along whatever rail was used.
By the 1840s engineers had settled on a minimum mainline radius of 804 metres.
In HO scale that is 9.2 metres.
(Most mainlines in Britain were built to a one mile radius ie. 1609 metres).
So all model or toy train builders simply required track systems to allow unimpeded travel of their flanged wheels.
The Märklin C track largest radius is about 1 metre (and their models are designed to run on a third of that radius).
That is 1/9th of what it should be if you wanted perfect scale.
But as explained by other contributors a 9 metre radius is entirely impractical for most operators of toy trains.
Offline Mr. Ron
#14 Posted : 13 September 2022 20:13:26(UTC)
Mr. Ron
Yes, I agree with this reply as S curves makes a whole lot of sense to me now.
thanks 1 user liked this useful post by Mr. Ron
Offline STE-BM
#15 Posted : 14 September 2022 08:24:01(UTC)
STE-BM
I grew up in the Alps and I’ve seen many S curved tracks. They exist primarily because of the difficult geology and secondary because space is limited and towns that exist for 100s or 1000s of years can’t be destroyed and rebuilt.
I picked a few examples close to where I grew up.
First you see there is a lake in the middle of two steep mountains. And the train track follows the natural shape of the lake with many curves. You can see also how they built a road and cycling path on each side of the track cause the space is very limited.
Caldonazzo lake train track
The second example S track is on a mountain, with an elevation, passing in between little towns plus some deep river crevasses to avoid etc etc.
Built in the late 1800 when tunnels were expensive and other engineering techniques were not available.
Mainly used for Commuters(Minuetto train) or freight trains coming from Venice/Est Europe and heading north Europe.
Edited by user 14 September 2022 23:21:20(UTC)  | Reason: Not specified
thanks 2 users liked this useful post by STE-BM
Offline Mr. Ron
#16 Posted : 14 September 2022 21:29:44(UTC)
Mr. Ron
I think I may have mis-informed everyone as to my definition of an "S" curve. I understand that track has to follow land contours, when necessary, but I am addressing curves that reverses in a very short distance where the curve resembles an S. I don't consider (for this definition) a curve reversing itself over hundreds of meters as a "S" curve; only those that do so within a very short distance. I realize why it is done on model railways, but it looks awfully Un prototypical, especially with long passenger cars. The small 4-wheel cars on European model layouts don't exaggerate their swing on curves like the passenger cars do. Just saying, but it reminds me of the unrealistic look of Lionel trains going around curves. I wish we all had the room to iron out curves for a more realistic look.
Offline Mr. Ron
#17 Posted : 14 September 2022 21:35:27(UTC)
Mr. Ron
I understand track has to follow land curvature, but even so the track is laid with minimum radii so "S" curves are "flattened" out so the reverse swing between cars is not so great.
Offline Mr. Ron
#18 Posted : 14 September 2022 21:45:47(UTC)
Mr. Ron
Duplicate post deleted.
#19 Posted : 14 September 2022 23:35:05(UTC)
Another pointliess S-curve? Here is a 2019 photo I shot of the warp in ICE track #5 at Hamburg-Altona terminus:
Guest (5)
This page was generated in 0.665 seconds.
