Offline skukuza
#1 Posted : 17 June 2022 08:57:30(UTC)
skukuza
Please can you help me?.
I have two grey 60113 connector boxes and two MS2.
Both MS2 units work perfectly when connected to my CS3+ or to a brand new 60116
When I connect both MS2's to one of the 60113 connector boxes the automatic search and registering for mfx loks does not work. I am able to load MM and DCC loks manually but not mfx. If I configure the MS2 for mfx only it will not discover any mfx loks.
This problem has only occurred recently after using the "find" facility. I very much suspect the software in the 60113 has become corrupted as I have the latest update which I have performed on many occasions.
The other 60113 connector box will not respond at all. Just the Maerklin logo comes up.
I have tried resetting to factory settings but there is no difference.
Is there a way of deleting and reloading the software onto the 60113 box?
Your help would be much appreciated.
Kevin
#2 Posted : 17 June 2022 16:13:55(UTC)
The color of the box doesn't matter. Both identical, but yours may need updating?? Try looking for MS2 updates on your CS3. If they appear, update both MS2's together, then disconnect them from the CS3 after you shut it down. Then connect them to the track box. The MS2 should ask once booted if you wnat to update the track box. If not, the box may be faulty, or if you execute the box update and it still doesn't work properly. Otherwise, I don't know.
This page was generated in 0.205 seconds.
