#1 Posted : 09 August 2020 21:16:12(UTC)
You have been a member since:: 15/10/2006(UTC)
Gerhards MoBa built an instance based on Jens Krogsgaard’s design and instructions
So you can pan the cube left and right while In motion.
If there was enough processing power to do image frame capture and processing on the board as well then automatic positioning to the track curvature would be possible but this doesn’t do that.
See Gerhards video using the camera car here :
thanks 10 users liked this useful post by Minok
#2 Posted : 10 August 2020 07:47:23(UTC)
That's pretty good - but I reckon, wait another couple of years and the Camera will probably be half that size again and twice the resolution :-)
Only problem with those is you have to get in super-detailing all the formerly hidden or unseen areas - engine sheds, tunnels, gullies etc
#3 Posted : 10 August 2020 13:53:05(UTC)
I have plans to do something similar with a Raspberry Pi W and camera, also with the RPi controlling a servo to adjust the camera.
This page was generated in 0.342 seconds.
