Offline dickinsonj
#1 Posted : 29 March 2018 22:01:21(UTC)
My VT 11.5 Helvetia quickly became a favorite of mine in the two years that I have had it. But now I am having a problem with it and I am hoping that I can get some ideas about what might be happening from the forum knowledge base. Cool
Two things started to happen recently, both are new but I don't know if they are related. When I reverse the direction of travel the lead power unit now makes a distinct clicking sound. It seems to come from the lower of the two PCBs and not from the PCB on which the decoder is mounted. I am guessing that it might come from whatever component switches the power pickup to the slider on the front of the train. I have checked and it is switching the slider input correctly and drawing power just from the lead power car.
I don't find the new sound a problem but there is a functional issue which started at the same time. Sometimes the train runs normally but at other times the rear power unit does not run at all and the front unit just slips its wheels trying to pull that heavy train without any help from the rear unit. The third option is that both power units do run but the train starts moving with a jerk, rather than accelerating smoothly.
The brushes are fine in the rear unit and it was cleaned and oiled just 4-5 weeks ago when it returned to my rails after about 6 months of storage. At first it ran normally but after several weeks this behavior began. I have never seen it do this when the operating sounds are not on and I am guessing that is somehow also involved. It seems to occur in either direction of travel, and it is always the default rear power car (without the decoder) that fails to run.
This is my first two motor train with direction dependant power pickup so I have no experience to guide me. I am hoping that someone can provide me with some ideas or it will have to get packed up and shipped off somewhere for repairs.
Thanks in advance for any input about what might be going on.
#2 Posted : 29 March 2018 22:26:22(UTC)
You have been a member since:: 01/03/2008(UTC)
Known problem. Glare
Has been discussed here before, mine did the same unfortunately.Cursing
But the clicking sound is normal IMHO, they all do it.
You may not have heard it before because the sound is simply deafening with this model!Laugh
But the "non-start in reverse" issue has to do with sticky brushes .
For some reason the brushes on these motors do not receive enough pressure from the little bronze springs, so that the least amount of contamination in the brush holder (carbon residue +oil) prevent the brush to come back to the commutator.
That it happened some time after you oiled it is a telltale sign.
You'll need to clean it once again, with lighter fluid (once again, my fav trick..) including the inside of the brush holder.
Then try to slightly increase the pressure on the springs by slightly bending them.
Repeat the treatment on the other side...because it will happen there too soon or later!
In addition I replaced the brushes, because I suspect the original were probably part of a lower grade lot. (otherwise, how would one explain it happen with just **this** one? )
Good luck
Jacques
Offline dickinsonj
#3 Posted : 29 March 2018 22:43:16(UTC)
Jacques
Thanks for that quick reply Jacques. Since I am mainly my own repair and maintenance shop at this point I don't think I could keep my trains running without the help I get here on this forum. Cool
I will pull the brushes, clean the brush plate and reassemble it with new brushes and tighter spring tension tomorrow. I have seldom run this train without the operating sound on, as I love the sounds of both diesels starting one after the other, so it might well have always done that. I don't understand why the problem seems worse when operating sounds are on, but if the brush maintenance fixes this I will be very happy.
I will report what happens.
Thanks Again. BigGrin
#4 Posted : 29 March 2018 22:47:34(UTC)
Jacques
do not forget to clean the inside of the little square tubes that hold the brushes. This is where they get stuck
Offline dickinsonj
#5 Posted : 30 March 2018 20:16:47(UTC)
Do not forget to clean the inside of the little square tubes that hold the brushes. This is where they get stuck
Thanks again for the advice Jacques and you were right about the cause of my problem.
Wow - was I amazed at the conditions inside those DCMs! I attached some images of what I found when I removed the brush plate.
I don't know if a brush was stuck or not but both motors were amazingly dirty inside, well beyond what I ever imagined considering how few hours I have run that train. I had not checked the brushes because I have DCM locos which are a lot older and that have never been anywhere near that filthy inside. I don't know if it was caused by bad brushes or maybe the heavy weight of that train, but now I will know to check those motors much more often. I also run that train in both directions and I wonder if that accelerates brush wear.
But they are both running fine again now and my lovely Helvetia is back on my track. Cool I need to buy more brushes though, since I still have a reasonable number of locos with those old style motors and I am now out of replacements.
#6 Posted : 30 March 2018 20:51:58(UTC)
Wow - was I amazed at the conditions inside those DCMs! ...
Glad it turned out OK for you.
Bad brushes, definitely.
Look for teh ones with a bronze hue in it.
Pure carbon (grey) is sh.t. Cursing
What good would be in all the years+countless hours of working on Märklin trains if it's not to share it with you all? Laugh Wink Wink
thanks 6 users liked this useful post by jvuye
Offline dickinsonj
#7 Posted : 30 March 2018 21:27:01(UTC)
Look for the ones with a bronze hue in it.
Strangely these brushes did have the bronze hue but they broke down into a fine black mess! The only brushes I see available online are #601460, which some dealers describe as flat carbon brushes.Confused
#8 Posted : 02 April 2018 19:34:22(UTC)
AFAIK there is only one reference.
Just don't know whether Märklin has only one supplier, and coherent quality.
It just seems to me that there are variations in the material . Some will wear out very slow, creating little dust, others will literally break apart.
The old ones last forever...
I reckon it's annoying...but as long as you know how to get around the problem, we'll just have to live with it.Wink RollEyes
Jacques
#9 Posted : 02 April 2018 20:10:26(UTC)
Great diagnosis Jacques!
I wonder is a small plastic 'extender' could be placed between the brush springs and the remaining brushes, to increase the pressure, (which must go down as the brushes wear...)
#10 Posted : 02 April 2018 20:55:29(UTC)
Maybe a possibility, but not in plastic: the bronze spring is a big part of the electrical contact.
Now, higher pressure won't help if the brushes are made of "chocolate" carbonLOL ...it will just make them break off faster. .
For the moment, I just replace them.
Offline dickinsonj
#11 Posted : 03 April 2018 00:43:41(UTC)
Jacques
Yes Jacques, that is how it seems to me as well.
Although all of these brushes have the same part number, they are indeed quite different in how they wear. Yesterday I got my California Zephyr back onto the track after a good while in the shop for various reasons. Considering what the brushes looked like in my two year old VT 11.5, I decided to pull off the brush plates and see what those DCM units looked like inside. Even though those locos are almost 19 years old they were much cleaner inside without all that mess. Sure, there was a bit of carbon dust, but not nearly as much and they were still running just fine. As you said, the old ones last forever...
I am just glad that there was a fairly easy answer and that I could get my beautiful Helvetia running again. It would be even better if we could figure out how to buy only the harder and longer lasting brushes but I can live with cleaning motors and replacing brushes if I must. Cool
Offline Drongo
#12 Posted : 03 April 2018 14:29:51(UTC)
Drongo
Jacques
From reading this thread about the carbon brushes, I come to the conclusion that Marklin at some stage decided to buy cheaper brushes, as you all say the old brushes were better. I beginning to believe that Marklin is hell bent on trying to destroy the "Marklin" name and if they continue with these "cost saving" exercises, they will certainly succeed and I don't want this to happen. Can someone please tell the Marklin management to wake up.
#13 Posted : 03 April 2018 16:29:18(UTC)
Not entirely new this issue with the brittle brushes.
There were a couple of other occurrences, at least in the mid 1990s and another one 10 years ago.
I've stopped worrying an bitching about it.LOL
Offline dickinsonj
#14 Posted : 02 May 2018 01:49:59(UTC)
I've stopped worrying and bitching about it.LOL
Me too- no bitching here. BigGrin Märklin is what it is and I for one am happy that they still exist. Cool
But I do have a related motor issue that sheds more light on this problem, which as you suggested Jacques appears more widespread than just one model.
Two weeks ago I bought a 26495 Montreal Limited train set. It was about 5 years old but still brand new in the original packaging. The ALCO PA-1s (PA-4s actually) are beautiful and I remain committed to the super robust and easily updated DCM powered locos. No bitching, honestly. BigGrin
However, I now have had a problem with it as well and it may be related to my VT 11.5's issue. I have always believed that some reverse running is good for a motor, particularly when it is new. So after running those locos for about a week I swapped ends and ran them backward for about 4 days. Then I returned them to the factory orientation to run them some more in the proper direction. But after about 10 minutes I noticed that the train had slowed down a lot and I shut everything down to investigate. Turns out that the rear DCM was still running strong - strong enough to skid that beast of a front loco along on its stalled traction tires! That loco had power but no motive power at all.
So I opened both of them up and I found a lot more gunk inside the brush plates than expected for just 5-6 hours of running. The brushes looked fine but I did not verify that they were free to move. I removed both brush plates and cleaned everything, checked the fit on the brushes and reassembled the motors. The commutators were pretty nasty, with no visible copper on the contact area left at all, but just black buildup. I cleaned them as well before reassembly. Now it is all working perfectly again.
So two things are in common between the VT 11.5 and the PAs beyond both having double DCM power units. Both models are extremely heavy, with the weight everywhere in the all cast construction VT 11.5. The PAs are nearly solid blocks of metal and weight a lot on their own - about as much as my Big Boy! So those DCMs are pushing a lot of metal in both cases and maybe even those torquey motors can't handle that much load. The other thing that they have in common is that I ran them in reverse and then shortly after going back to normal running, one of them stopped. I run the VT 11.5 in whatever direction fits on my track, so it may easily be running in the reverse direction at any time. I ran the PAs in reverse purposely to "break" them in. BigGrin So maybe that backward running does not bed in these brushes but rather tears the hell out of them and screws up the motor.
They are both rotating off of my layout anyway and they are both running perfectly as I pack them up. It will be interesting to see how they behave when I get them out next time and I am going to try to avoid running them backward. My 19 year old California Zephyr still runs perfectly with just one change of brushes in all of that time. Because of its A-B-B layout it is hardly ever run in reverse, but in addition, it does not weigh anywhere near what the ALCOs do.
I would be interested in hearing if anyone has had similar DCM issues and can see any pattern in this stuff. I only have those three double DCM trains for comparison and that is too small of a sample. My single DCM powered locos all run perfectly with only occasional, basic service. I will continue to use and love them as always but I will be keeping a much closer eye on them in the future. I never assumed that would be needed with such a normally robust and basic motor as the DCM, but apparently I was wrong.
Cheers.
#15 Posted : 02 May 2018 02:08:25(UTC)
My locos with double DCM motors are 6 Alcos,7 EMD F7 and 1 V188.I faced the problem after a lot of years only once with the Alco 37612.
Offline dickinsonj
#16 Posted : 02 May 2018 03:18:23(UTC)
Wow - what a nice collection - Thanks for the input! That is definitely a better indication of potential problems than just my small sample. It seems that luck has not been with me!
Good to know that this problem might not be widespread, since mine are some of my favorite models. BigGrin
Maybe this is just a batch of bad brushes in the trains that I have bought - the luck of the draw as we say. I do know that my older DCM models have been very reliable over the years and required almost no care or feeding. There really is not anything different about these motors otherwise, so bad brushes make sense to me.
Time will tell how mine do in the future and I do intend to replace the brushes when I get the chance to run them again. I also intend to run them less in the reverse direction in case that is part of the problem.
#17 Posted : 02 May 2018 05:49:40(UTC)
I forgot F7 39621 and VT 11.5 37609 so two more.The reason i had the problem with the 37612 was too much oil in the motor.It was my fault.With this kind of motor is better to leave the motor without oil,you will hear the noice and you will oil her on time and no problem.Too much oil is always problem.
Enjoy your locos.BigGrin
Offline dickinsonj
#18 Posted : 02 May 2018 12:56:58(UTC)
With this kind of motor is better to leave the motor without oil,you will hear the noise and you will oil her on time and no problem. Too much oil is always problem.
I will enjoy these beautiful locos and I will keep an eye on the amount of oil. The person I bought it from oiled them and tested them before sending them to me. When I took the brush plate off there was more oil inside than I expected, so that may have been the problem. I wish Märklin had stuck with the bearings for these motors, which would make them much nicer.
Thanks for the advice.
Offline skeeterbuck
#19 Posted : 02 May 2018 18:57:01(UTC)
skeeterbuck
Jim, Maybe consider changing then over to ball bearings. If you do just be sure to get the sealed type. You wouldn't want that brush dust getting into an open bearing. Also, you wouldn't need to worry about oiling them. I've done two so far and while I'm not going to frantically go through each engine and convert them over, when they go into the "shop" for maintenance they'll get upgraded.
Chuck
Offline dickinsonj
#20 Posted : 02 May 2018 20:30:27(UTC)
Chuck
Good advice Chuck, and that is on my todo list.
I have read about people doing that upgrade but I don't have a drill press and I am afraid that I would not get the hole in the brush plate exactly centered if I just use a hand drill. I can't imagine that the motors run very well unless the bearings line up perfectly.
How did you drill the hole in your brush plate? Does the one in the metal casting just replace the plastic insert that Märklin puts in when they make them? I have also not been sure where to buy the sealed type bearings. If I did that I do think it would eliminate the brush breakdown problem which does seem to be caused by too much oil. I will have to speak to my lazy, grouchy shop foreman and see if I can get some of mine done too. BigGrin
Offline Ross
#21 Posted : 05 May 2018 01:53:13(UTC)
Ross
Hi Jim,Jacques and All,
I run the VT11.5 on my layout in equal amounts of forward and reverse running and noticed a drop off in performance so I decided to service it yesterday.
Both motors looked like the photos Jim provided. After a thorough clean and new brushes I was disappointed to find the running hadn't improved.
Further investigation was required and I started by the just connecting the engines together and laying them on their side on my work bench.
A jumper lead was clipped between both collector shoes and then I applied my programming track power to the locomotives.
I tested the locos by running at full speed then applying pressure with my fingers to the drive wheels.
The forward loco with the decoder had a lot of torque but the rear loco had little to no torque and I could stall the drive wheels.
I dismantled both locos and measured the winding of each armature. I applied a small white dot to mark the start position then measured the ohms between the
solder tabs on each side of the coil. I move in a clockwise direction until I had made five measurements the results shown below
Good armature 8.3, 7.8, 7.7, 7.8, 7.7
Bad armature 9.1, 9.3, 35.8, 9.4, 9.2
The high measurement indicated that the armature coil was damaged.
I didn't have a spare armature to suit so I removed the armature from another locomotive and after re assembly of the VT11.5 it ran as good as new.
I will be looking to service this train more often to try and prevent this from happening again.
Ross
Offline dickinsonj
#22 Posted : 05 May 2018 02:14:01(UTC)
After I worked on mine this year I decided to have spare brush plate/armatueur sets on hand for them. I have older dcm locos which have never had a moments problems so I am at a loss to understand why these are so delicate.
I still love them and I will still run them however fits - that after all is the point of a double ended train set like that. I will just know to keep a close watch on them. I also want to try a ball bearing upgrade on one of them to see how that goes. I oil these just like I have oiled dcm locos for 30 years and the newer ones are the only ones I have seen get so wasted in just a few hours, rather than a few years of use.
This will always be a favorite train of mine though - I just need to figure out how to live with it - kind like the wife. BigGrin
Offline Ross
#23 Posted : 06 May 2018 02:31:23(UTC)
Ross
Hi Jim/All,
It has been mentioned that the train is very heavy so I thought I would weigh it and do some extra measurements.
37605 set total weight = 1656 gm and contains
Loco Front with decoder = 510 gm
Loco Rear = 490 gm
Car 1 = 330 gm
Car 2 = 326 gm
43115 Coach set total weight = 972 gm and contains
Car 1 = 328 gm
Car 2 = 324 gm
Car 3 = 320 gm
Total weight of VT11.5 train with 5 cars and 2 locomotives = 2628 gm
5 Cars = 1628 gm
Draw bar pull for 5 cars on level track is 50 gm
Draw bar pull for 5 cars on 4.5% grade is 160 gm
The problem is the weight of the train and the amount of effort for the train to handle grades. I don't think a ball bearing upgrade will improve this situation.
The 37605 has the ball bearings and the 37607 doesn't have the ball bearings, both trains slow down on the grades on my layout.
For people who have a version of this train running on the level requires the least amount of effort and should run longer between services. If your layout has grades the train requires more effort for the grades and will require regular service at shorter intervals to prevent the armature from being destroyed as in the above example I have tried to illustrate.
For people that have the gold version can you supply the weight to see how much weight the gold adds to the train.RollEyes
Ross
thanks 5 users liked this useful post by Ross
Offline dickinsonj
#24 Posted : 06 May 2018 14:49:04(UTC)
Hi Jim/All,
Interesting information about just how heavy this train really is Ross. Thanks for the insights. Cool
I don't believe that ball bearings would improve the performance of these motors, but I still wonder if oil in the motors is contributing to the breakdown of the brushes. If that is the case then the ball bearings would help. That was a good comparison between the performance of 37605 and 37607 on grades, and provides more insight into the limited pulling capacity of these locos.
These dcm units represent extremely old technology and maybe in these heavy models they have finally met their match. I have seen how they can be replaced with modern motors but it is a pretty drastic action involving irreversible changes to the power trucks. My current plan is to run and enjoy my dcm locos and to keep a closer eye on their status and to have some spare brush shields, brushes and stators on hand. In time I could become brave enough to replace the motors in the heaviest locos but for now I will just wait and see how it goes.
Cheers!
This page was generated in 0.812 seconds.
