Offline guitartoys
#1 Posted : 02 November 2017 00:23:24(UTC)
guitartoys
Views messages in topic : 27
Hello again,
I've been reading a bit about noise control on layouts, and wanted to hear some feedback
In reading CTI's app notes:
First, on motors I hear that using a .01uf or .1uf cap is good for noise suppression. I was wondering if any of you all have been doing so.
Also, to put snubber diodes on solenoids also for noise control. So something like a 1N4002 to clamp the spike when disconnecting the voltage to the solenoid.
Just wanted your input, as I start down this path to put the diodes and caps in place as I go.
Also, instead of using the straight flat 3 conductor Marklin wire for the turnouts, to use individual wires, and twist them. Just wanted some insight into that as well.
Thanks.
Michael
#2 Posted : 02 November 2017 19:45:05(UTC)
The diodes across the coil inputs of a solenoid/relay is not so much noise suppression as to protect other sensitive equipment, because not having it will introduce a large voltage spike when the coil switches off due to the stored electro-magnetic flux in the coil. That high voltage over even a short time can damage some types of electronics such as semiconductor decoders so its a protective measure.
This page was generated in 0.415 seconds.
