Offline Jabez
#1 Posted : 22 February 2017 01:27:15(UTC)
Jabez
This is more of a question than a review.
I have an old M 4631 Self Unloader wagon probably from the 70s. It has a vertical rod protruding down through the chassis which can be engaged by an uncoupling rail to actuate the side doors for automatic unloading. M doesn't appear to offer a similar mechanism on its current self-unloader cars.
I wonder why they dropped this interesting feature? Possibly because it was more interesting than practical and might be more messy than accurate in operation?
#2 Posted : 22 February 2017 04:57:36(UTC)
I have a SBB version of this car from the 29859 Set (2001). That model had the Maerklin 7203 couplers, but did not have the close coupling mechanism.
I don't know if there were other versions since then.
#3 Posted : 22 February 2017 08:08:23(UTC)
Then why isn't it in the H0 section?
It definitely does not quality for the Review section.
Offline Jabez
#4 Posted : 24 February 2017 00:07:54(UTC)
Jabez
Since it specifically focuses on one particular item of rolling stock, I was a bit unsure where to post it. That's why I opened with with the disclaimer effectively inviting a moderator to move it into whatever section was thought most suitable. Clearly it was not thought necessary to move it from where it was posted.
Offline Jabez
#5 Posted : 24 February 2017 18:02:20(UTC)
Jabez
But it has found its true home now, so I guess all are happy.BigGrin
