General topics
Digital
Marklin 39500 upgrade with msd decoder not moving
Joined: 27/02/2008(UTC) Posts: 297 Location: Santiago
Hi, I have made the upgrade of the decoder of my E50 model 39500 with an msd decoder, but I can't make it run. I have changed all CVs for the soft drive, and I have added AUX 4 in S and F. I am missing something else on the conversion? I did I an exact copy of the parameter already present in the original decoder but still I can't make it to move. Anyone around there with experience making this kind of upgrades? I have done in the past sound upgrades but with ESU decoder so with no problem. Do I need to do something else with the msd decoder?
Thank you
Joined: 16/02/2004(UTC) Posts: 15,463 Location: DE-NW
Hi! Originally Posted by: eduard71  I am missing something else on the conversion? Which colours does the original decoder have? If it is blue, then you will need a NEM-compatible decoder (MSD Spezial or ESU). If the original decoder is blue then hopefully the MSD did not damage the board in the loco. If it is red or green then take a close look at the decoder to find whether it is NEM-compatible or nor. |
 1 user liked this useful post by H0
Originally Posted by: H0  Hi! Originally Posted by: eduard71  I am missing something else on the conversion? Which colours does the original decoder have? If it is blue, then you will need a NEM-compatible decoder (MSD Spezial or ESU). If the original decoder is blue then hopefully the MSD did not damage the board in the loco. If it is red or green then take a close look at the decoder to find whether it is NEM-compatible or nor. Thank you very much Tom. The original decoder is blue with no sound it is an ESU one. I now know that msd decoder have amplified aux 3 and 4 so they will not be able to run soft drive motors and only the special one can do it. Thanks again Eduardo
 1 user liked this useful post by eduard71
Originally Posted by: eduard71  Thank you very much Tom. The original decoder is blue with no sound it is an ESU one. I now know that msd decoder have amplified aux 3 and 4 so they will not be able to run soft drive motors and only the special one can do it.
Did You now check, if the loco is still working with the original Esu decoder? I would do this first to be sure, the mSD didn't damage the SDS-Board. Moritz |
Originally Posted by: Moritz-BR365  Originally Posted by: eduard71  Thank you very much Tom. The original decoder is blue with no sound it is an ESU one. I now know that msd decoder have amplified aux 3 and 4 so they will not be able to run soft drive motors and only the special one can do it.
Did You now check, if the loco is still working with the original Esu decoder? I would do this first to be sure, the mSD didn't damage the SDS-Board. Moritz Hi Moritz, Yes it does, I was looky and the board didn't suffer any damage. The locomotive is working with no problem. Regards Eduardo
 2 users liked this useful post by eduard71
General topics
Digital
