Offline thomas buckley
#1 Posted : 18 February 2016 22:19:31(UTC)
thomas buckley
I acquired a z scale collection(small) and two of the locos do-nothing when put on powered track. The third loco runs on track so that part of diagnosis is eliminated. Are there any steps I can do to get these locos going or is it something left to a service place if there are any you recommend?
#2 Posted : 18 February 2016 22:26:55(UTC)
Maybe HOS. Can be cured with TLC.
HOS = hardened oil syndrome
Hardened oil can lock the gears and prevent locos from running. A long swim in a degreaser could help.
Are the lights on the locos working?
Offline hgk
#3 Posted : 18 February 2016 23:57:47(UTC)
hgk
For HOS I usually remove the plastic body and blast the gearing with CRC contact cleaner until it gets running then give it a drop of train oil on the gearing points of contact.
If the nonworking engines have pantographs then its possible that the selector switch is in the wrong position.
See the respective marklin instruction sheets for oiling & switch location.
-George
thanks 1 user liked this useful post by hgk
#4 Posted : 21 February 2016 17:59:36(UTC)
thomas buckley
if the lights are not working, is that terminal? theCRC cleaner is not damaging to any components? It appears I will be breaking out the high power reading glasses for delicate surgery:)) Any advice on what not to inadvertently damage? Thank you in advance!!
Offline hgk
#5 Posted : 21 February 2016 19:38:36(UTC)
hgk
Do not use any contact cleaner on any plastic shells. Remove painted metal shells as well.
This is what I use- http://www.homedepot.com...leaner-02130-6/202262505
You should read the specs for whatever product your using.
Lights not working could be a bad bulb or an open circuit. Do you have the model numbers or a photograph of your locomotives?
If you have the body shells off, then photos of the frames might point to something amiss.
George
Edited by user 24 February 2016 02:56:00(UTC)  | Reason: Not specified
#6 Posted : 23 February 2016 18:06:39(UTC)
thomas buckley
Thank you for the help. This may be inappropriate but I live near the store indicated in the link you supplied. Just wanted to say howdy neighbor! I have to do some research for the loco model numbers ...Thanks again!!
Offline hgk
#7 Posted : 24 February 2016 02:21:37(UTC)
hgk
It might be quicker to post a photo as a lot of members here are very good at identifying marklin items.
www.zscale.de has lots of marklin photos and catalogs, as well as www.marklin.de
Guest (4)
This page was generated in 0.321 seconds.
