Offline Br502362
#1 Posted : 07 January 2016 16:37:15(UTC)
Br502362
Last evening I was running some trains in my layout. After some minutes I heard one of the transformers making
that "ding" sound when there is a short some where. A quick glanse around the track... and WHAT??? Smoke rising
from 4078 "Kakadu" restaurant/luggage wagon at the station. Quickly power off and I pulled wagons with loco towards me.
I took the smoking Kakadu to side and started to investigate what has happened. The tin body was warm nearly hot!
I took the roof away and the smell was terrible. Led bulb had gone short and melted the light diffusor, burned the white
cardboard to brown and made a black burn mark inside the roof.
I have had problem with these led bulbs before. Two have just made a snapping sound and went dead but never something like that!
# 600150 LED
Let's be careful out there Wink
Åke
Edited by user 08 January 2016 10:34:31(UTC)  | Reason: Edited wrong item number
thanks 5 users liked this useful post by Br502362
#2 Posted : 07 January 2016 18:31:25(UTC)
For which voltage are those LED bulbs specified? Do you have a digital layout? Which controller? Which power supply?
Offline Br502362
#3 Posted : 07 January 2016 20:50:08(UTC)
Br502362
They are for 16-22V and my layout is analog. Power supply is white 32VA Märklin transformer 6647.
Åke
#4 Posted : 07 January 2016 20:59:29(UTC)
So it seems they get too hot even when used within specified parameters.
Scary as they could damage plastic parts of locos or coaches - and they did with your dining coach.
And LEDs are intended to reduce excessive heat and current draw.
#5 Posted : 07 January 2016 21:18:14(UTC)
Yes, but there is a single LED per bulb, and for 16-22V supply there will be a reasonable size resistor in there, or the resistor is too low a value and the LEDs are running at excessive current. This is where the modern 'LED strip' is much better as the dissipation is distributed.
Offline Shamu
#6 Posted : 07 January 2016 23:22:14(UTC)
Shamu
I had in the past considered using these type of replacement bulbs for convenience sake but have decided to make them myself on a cost per unit basis.
As Tom mentioned a real worry in the context of plastic locos/wagons. Would be interesting to know what value resistors (or maybe zener) has been used in these led bulbs.
Of a far bigger concern to me is the emergence of domestic LED light bulbs.
thanks 2 users liked this useful post by Shamu
#7 Posted : 08 January 2016 02:51:15(UTC)
I am a little confused. The 4087 is a TEE Restaurant coach. It is not a Kakadu, nor is it a luggage coach. The coach is equipped with a seating area and a kitchen. The kitchen has an access door which you might have misinterpreted as a luggage area. Or did you mistakenly write 4087 instead of 4078?
WRmz132 4087: https://az95169.vo.msecn.../images/marklin/4087.jpg
The Kakadu (ARm) 4078: https://www.marklin-user...cs/rayf/4078%20-%201.JPG
Are the LED bulbs made by Maerklin or approved by Maerklin? I have had at least one occasion where a bulb overheated and melted the light channel. Fortunately, it was discovered before the heat did any damage to the plastic coach shell.
I am glad that the damage was primarily limited to the light channel. You should be able to find a replacement. Have you considered replacing the original lights with a LED strip that you could attach to the inside of the roof with two sided tape. this might be a better solution that using a LED in the socket designed for the original bulbs.
Offline Br502362
#8 Posted : 08 January 2016 06:58:27(UTC)
Br502362
Hi Mike,
You are right. It should be 4078 of course. My mistake on the keyboard Unsure
No those led bulbs are not approved by Märklin but commonly sold at German Ebay.
Fortunately it wasn't plastic coach! And yes... led strips would be superior compared to these led bulbs
but I wanted to use the existing light diffusors so I went with led bulbs. All my plastic coaches have led strips
or conventional bulbs.
Åke
Offline Gregor
#9 Posted : 09 January 2016 10:22:05(UTC)
Gregor
Thanks for the warning! I have installed them in some of my coaches, but I do not really like them, as the light they emit has a greenish colour. I bought them from Conrad.
Do they get hot during normal use, or only if they malfunction (internal shortcut or something similar)?
I can't check right now because my layout is covered in plastic. I am redoing my layout room.... Haven't run my trains since October... Sad
Gregor
thanks 1 user liked this useful post by Gregor
Offline Br502362
#10 Posted : 09 January 2016 11:31:07(UTC)
Br502362
Gregor
Hi Gregor,
They stay cold in normal use so there's no problem.
I hope that you get your layout room ready soon ThumpUp
Åke
Offline ealab
#11 Posted : 16 January 2016 12:11:56(UTC)
ealab
Hello/Terve!
Must pay attention to this maximum LED current. You can measure the LED current(20mA typ) in the normal operating voltage. If the current is approximately 20mA, then put in addition to a series resistor. 1kOhm/0,25W probaly suffice. The power need not be exatly 20mA, may be less, when only the light going to.
www.veturitalli.fi and www.rautatieasema.org -pages of these stories. Also the interior light flicker.
se on moro vaan
ealab
Edited by user 16 January 2016 20:37:49(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by ealab
Offline Br502362
#12 Posted : 16 January 2016 12:52:42(UTC)
Br502362
Originally Posted by: ealab Go to Quoted Post
Hello/Terve!
www.veturitalli.fi and www.rautatieasema.org- pages of these stories. Also the interior light flicker.
se on moro vaan
ealab
Hi/Terve Smile
Ok. Must check that too. Fortunately the lights don't flicker.
Thanks for the info and links ThumpUp
Sommoro
Åke
This page was generated in 0.525 seconds.
