Offline Oliver nagel
#1 Posted : 15 May 2014 03:35:04(UTC)
Oliver nagel
Today I got in the mail a new old stock Br 103 3358 the red one. I took the body off and the has a nice 5 pole armature motor a electronic reverse relay. I want to convert the lok to digital so I need a new magnet. I have nice Esu decoder V4.0 I just need the magnet part number.
Thank youConfused
Offline 3rail4life
#2 Posted : 15 May 2014 04:55:40(UTC)
3rail4life
The ESU Hamo magnet # 51962 or the Märklin #235690 are the ones to use with the existing motor parts.
I was think of trying this myself, as I was wondering how well LoPi 4.0 would work with the old 5* analog motor converted to DC, sounds interesting...
Gordon
#3 Posted : 15 May 2014 05:37:32(UTC)
All the part numbers for these types of conversions are listed in this (sticky) topic in the Digital forum.
https://www.marklin-user...nversion-of-M-locos.aspx
You could also use the 60941 motor kit for a full 5 pole motor upgrade, but the HAMO magnet will work reasonably well. I converted my 3358 with a 60760 kit, which works quite well.
#4 Posted : 15 May 2014 08:00:05(UTC)
Oliver, unless the loco has been converted at some stage, there is nothing to suggest this loco came with a 5 pole motor, if we talk about a 3558 than we can include the 5 pole motor as a standard motor.
changing the 5 pole motor with an ESU magnet should do the job as the 5 pole motor has the same diameter as a 3 pole motor.
you most probably find paying a few more dollars as Dave mentioned a 60760 (with decoder) or 60941 conversion set (without decoder around the US$ 36.00-39.00.
your ESU decoder version 4 would be ideal for the conversion set, especially at the lowest speed level.
#5 Posted : 15 May 2014 08:59:21(UTC)
Hi Oliver,
Remember to change the light bulbs to the correct ones for digital. The 33xx locos were equiped from factory with low voltage bulbs (~3V?) and I've blown up a few in the process of digital conversions!
#6 Posted : 15 May 2014 15:18:02(UTC)
Oliver nagel
I looked though old posts found for part information on the 3358 didn't find any. I took some pictures so you know what I mean.
Oliver nagel attached the following image(s):
thanks 1 user liked this useful post by Oliver nagel
Offline 3rail4life
#7 Posted : 15 May 2014 16:31:55(UTC)
3rail4life
Hi Oliver,
Thanks for posting the pictures, nice model, I have the same loco, but it is the 3558. According to Märklins parts lists both the 3358 & 3558 came with the 610030 five pole armature originally, which is unusual for a 33xx series loco.
parts lists
or : http://www.maerklin.de/s...1&artikelnummer=3358
I think you will be ok with those bulbs, they may be a bit bright so you may want to dim them or change to 600800's. Funny Ray should mention the low voltage bulbs, I just blew one up the other day with an analog trafo testing it, I felt pretty dumb for forgetting about thatCursing.
Cheers, Gordon
This page was generated in 0.502 seconds.
