Joined: 25/12/2011(UTC) Posts: 194 Location: Tennessee, USA
Hello the Forum,
I’m trying to replace old Marklin 6083 k83’s with new Viessmann 5211’s to control Marklin 7040 & 7039 semaphores. When I connect & power a 5211 by track current, nothing happens, not even lights. If I use an external transformer, the semaphores light properly, but switching is unresponsive. Same problem when I try to power a 24997 uncoupler.
I’ve triple-checked instructions, wiring & plugs, dip-switch settings, etc. Everything works fine with the old k83’s, but not with the 5211’s. What am I doing wrong?
FYI – Control is via a CS2 or an MS2. Transformers are a 60 VA 60055 with the CS2, and a 42 VA 6001 for external power, or alone with the MS2. The problem is the same with all set-ups I’ve tried.
I’m frustrated, and any advice will be much appreciated.
Thanks -- Richard
Long-time analog user, collector & tinkerer. Discovered digital & began conversion a few years ago. C-Track, CS2 Carpetbahn built, taken-down, rebuilt, etc. Username reflects how much I still have to learn. |
Thanks -- Richard
Viessmanns 5211 don´t have same connecting as Marklins k83. Did you followed manual with 5211? Never use external power for 5211 when you use Marklins digital system. Digital system feeds power to the decoder k83 or 5211. But you must connect 5211 as manual shows. |
H0 DCC = Digital Command Control
 1 user liked this useful post by Goofy
Joined: 08/03/2006(UTC) Posts: 1,047 Location: Gold Coast, Australia.
D.A.Banks |
 2 users liked this useful post by Dave Banks
No no no!!! Never use Brown wire and yellow wire connect to digital Power!! Or else you burn out switch function in the toilett!! |
Anders, On this occasion I have kept the Signal / Point switching separate to the digital system & only connected to my Ecos 50200 via the cable provided from the Marklin 6017 booster. Sorry I should have pointed that out. Dave... |
D.A.Banks |
Joined: 15/08/2010(UTC) Posts: 301 Location: Bay Area, California
Hi Richard: Marklin K83 and Viessmann 5211 are almost identical with two exceptions: a) the most obvious is that the Viessmann decoder can be programmed without disassembling the case b) the "red" terminal E of the Viessmann decoder. This connection has to be powered by an external transformer (=from a non-digital source) in order to switch your signals. This avoids "wasting" digital current. To connect an external transformer, connect the brown cable (=ground) to the brown terminal, and the yellow cable from the outside transformer to the red "E" terminal. Otherwise, the connections are identical to the Marklin K83. If you don't want to use an external transformer, just connect the red "E" terminal to the red cable coming from the digital source. In both cases, the terminal "E" must be connected either to an external transformer or to a digital source. There is no risk of incompatibility between an external transformer and for example a Marklin central station. The two sources of current are indeed insulated from each other in the Viessmann 5211. I have a few of those and I have no conflict at all between the two sources of current. In your case, I am wondering however if the coils in the Marklin 7039 and 7040 are drawing too much power from the Viessmann decoder and made the switching impossible. In any case the terminal "E" must always be connected. I have attached the Viessmann cabling schematics (in German and English). Figure 1 represents the way the decoder must be connected without an external transformer. The second figure illustrates how the connections are when the decoder is connected to both digital and analog power sources. Regards, Pierre File Attachment(s): Scan.pdf (768kb) downloaded 105 time(s).
 2 users liked this useful post by Caralain
Originally Posted by: Caralain  Hi Richard:
Marklin K83 and Viessmann 5211 are almost identical with two exceptions . . . . . . .
In your case, I am wondering however if the coils in the Marklin 7039 and 7040 are drawing too much power from the Viessmann decoder and made the switching impossible. Goofy, Dave & Caralain – Thanks for responding so quickly and well. The VM 5211’s now work fine with track power. And it is a different wiring scheme than for the k83’s. I still can’t power them with an external transformer, but will try carefully again today. To help others who may have similar problems, I’ll add photos like DaveB’s in a day or two once I’m sure the solutions work. I’d much prefer to use an external transformer, but I’m happy the switches at least “switch” now with track power. Thanks again – Richard |
Originally Posted by: DumbGuy  To help others who may have similar problems, I’ll add photos like DaveB’s in a day or two once I’m sure the solutions work. I’d much prefer to use an external transformer, but I’m happy the switches at least “switch” now with track power. As promised, the photo below shows basic wiring differences between my Marklin k83 and a VM-5211. Power and ground inputs for both are from digital track current. Each unit is shown with a 7040 Semaphore connected. Wired as shown, both work well. The need for the extra top-to-bottom input wire shunts on the 5211 doesn’t make sense to me, but I’m not able to make the unit functional without them. I have still not been able to successfully use the 5211 with an external accessory transformer. Comments, explanations, or other options appreciated. Update on 18 December . . . . . The wiring shown below works well for powering from digital track current. See Post #11 for differences when powering from an external transformer. Both ways work for me, but please correct if anything appears "dangerous".
Best regards for the Holiday Season -- Richard Edited by user 18 December 2013 06:21:28(UTC)
| Reason: Update DumbGuy attached the following image(s): |
 1 user liked this useful post by DumbGuy
Joined: 23/08/2006(UTC) Posts: 2,597 Location: Beverly, MA
Quote:Never use external power for 5211 when you use Marklins digital system. Nonsense!
 1 user liked this useful post by kbvrod
Originally Posted by: kbvrod  Quote:Never use external power for 5211 when you use Marklins digital system. Nonsense! Sorry...my fault. |
An update & my last post on this topic. The VM-5211’s work well now with external power & wiring is simple. Referencing my photo in Post #8, I removed the two short shunts, then rewired as: (1) Red “E” & Brown ground (at top) to an external accessory transformer; (2) Red power & Brown ground (at bottom) to digital track current. Semaphore connections are unchanged.
Simple to do & my earlier mistakes remind me of why the Username I’ve chosen is still totally appropriate. Per the last two Posts, VM-5211’s do work very well with Marklin Digital.
Regards – Richard
Hi Richard,all, When I built my ETE modules and old layout,I used the 5211 because,they were cheaper than the M k83's and you could use an external power supply.Two good reasons,IMHO,... My situation was different: points were thrown via Peco solenoids and Viessmann signals(which like M can have the lights powered separately.)Thus saving more power for trains,... Good to hear that the problem is solved. Dirt
Originally Posted by: kbvrod  When I built my ETE modules and old layout,I used the 5211 because they were cheaper than the M k83's and you could use an external power supply. Two good reasons, IMHO,...  Dirt -- OK, one last post just to praise Viessmann a bit. I agree with your “two good reasons”. Mine were the same. For similar reasons, I also use VM products for most of my turnout decoders (VM-5231) and LED switch lanterns (VM-4555) with excellent results. Main problem is that VM products are often hard to find in-stock from US suppliers (or even from US eBay). And though they make many other items that are Marklin-compatible, I’ve not tried more. Regards – Richard |
Hi Richard,all, Quote:Main problem is that VM products are often hard to find in-stock from US suppliers As are many products inclusive to Germany,so you order from your favorite shop,.....and there are many shops,here and there that will find these items,... Dirt
Joined: 17/09/2006(UTC) Posts: 18,778 Location: New Zealand
The K83 isn't designed to control track power, it is designed to activate another device such as a signal, turnout or relay. In your case you need to use a relay in conjuction with the k83 to control track power. Or you could use a k84 (V5213) to do this. To answer your points :- 1) That's OK, or you can use the yellow from a separate transformer 2) R/B connections don't have to be from the opposite side - I always use the ones next to the 'E' socket. The R/B sockets at the bottom are there to daisy chain to another 5211. 3) Good! 4) Here is where you are going wrong. The Y/R/G should go to your signal solenoid, turnout, or you can use a Marklin 7244 relay. The R/G are actually ground connections, and are used to close the circuit from the yellow connection - if you connect those to your centre rail you will most likely get a short circuit. http://www.ajckids.com/products/Marklin/7244
I've used both solutions. In the case where I wanted track control but there were no signals (for use in a shadow storage yard) I used K84's. In cases where there were signals, I've used a K83 along with a 7244 relay to control track power.
I've only ever used the V5213 K84 and don't have any experience with m84's, so can't comment there.
