Offline danmarklinman
#1 Posted : 01 December 2013 17:48:22(UTC)
danmarklinman
Just out of interest. How long will it be before marklin and others have a hub connection with your layout and therefore no longer any use for. Cs2 just an iPhone or tablet instead!
I am waiting myself for this as I like tech which is multi use BigGrin
Wiking model car Fan
Instagram: marklin1978
Wiking fan
#2 Posted : 01 December 2013 18:57:45(UTC)
Hi, Dan,
That's not science fiction, it's already there.
Roco's Z21 (and z21) have no display and no speed knob, instead include a WLAN router and you operate your trains and turnouts with a smartphone (or with a mobile controller with wire).
ESU and Märklin still have touch screens and speed knobs, but you can also control trains and switches with a smartphone. They could make special versions for PC and smartphone operation, but neither of those seems to see enough demand for that.
See: www.z21.eu
Offline jeehring
#3 Posted : 01 December 2013 19:17:23(UTC)
jeehring
Smartphone as an option : I say OK !
Smartphone as main control: I say NO , thank you ! (I don't like)
thanks 5 users liked this useful post by jeehring
#4 Posted : 01 December 2013 19:55:41(UTC)
But you use smartphone as main control too or even better with ipad with bigger screen.
#5 Posted : 02 December 2013 00:26:56(UTC)
I think using a smartphone as a loco controller has some way to go before it is mature enough to use on a daily basis.
In my experience it is all too easy to accidentally set the loco speed to maximum - can be done unintentionally by bumping the phone (and that's with all motion sensing turned off on the phone)
Applications will often exit for no reason - I have experienced this with both an ipod and S3 android phone.
Offline Janne75
#6 Posted : 02 December 2013 05:52:26(UTC)
Janne75
For me personally CS2 or similar "main" controller is needed also in the future. I use both Mobile Station app for iPhone and Main Station app for iPad also, but only as remote controllers to avoid the need to stay near my CS2 all the time when running my trains.
With touch screen applications everything can happen and I think these apps give some extra to this wonderful hobby, but it would not be good to be without my CS2. Many things are far easier to do with CS2.
CS2 takes some space near layout and the only good thing really from taking it off would be to get more free space + price for controlling trains could be (maybe?) less without it...
Just my thoughts... RollEyes
Janne
Offline sjlauritsen
#7 Posted : 02 December 2013 23:19:48(UTC)
sjlauritsen
Whatever will happen, I personally hope that Märklin will build a Windows Phone and Windows 8 app before ditching the CS2 and MS2. I will not buy an Iphone og an Android device just to be able to run my trains.
My greatest concern about the Z21 is that many people do not necessarily have smartphones or the skills to setup a wifi router etc. I think its a deal breaker when you need an Iphone or an Android device to run trains. They should include some sort of handheld controller with every startset instead of relying solely on smartphones.
Don't get me wrong, the smartphone is a cool alternative, but I currently do not think it should be a requirement.
Søren from Denmark
thanks 3 users liked this useful post by sjlauritsen
#8 Posted : 04 December 2013 21:12:42(UTC)
So just like me then - waiting for an app for WP8/RT/Win8....
Offline TouchCab
#9 Posted : 04 December 2013 22:09:01(UTC)
TouchCab
As others have mentioned, the Z21 is the first system we've seen without any other controller than what's on the network. Allegedly the Z21 accepts all kinds of other connections, but I have not seen test reports about how that works, and the system does not come with a hardware based controller out of the box.
Looking at the market, I think other manufacturers are watching how well the Z21 is doing before trying anything similar. The major obstacle is that the IPv4 networking protocol was never built for everyday people to use, and although there are higher layer protocols to overcome some of the problems (PnP and Bonjour/zeroconf/Avahi), compatibility is an issue. My largest support issue by far is networking - especially when users have a setup that is not straight forward.
The next generation network devices using IPv6 should have zero configuration networking built in, but I haven't investigated the matter further than that. Hopefully that will make home networking as plug-and-play as USB is today. By then, you'll probably also be able to operate the layout from a touch screen on the door of your refrigerator ...
BigGrin
Anyway, as I see it, the market must first mature to the point that home routers and the things that people attach to the network at home are all using IPv6. I do think the manufacturers are paying attention, though, because there is a lot of money to be saved if they don't have to make the hardware and mechanical parts for dedicated handhelds.
Jens
This account is no longer active
Offline rhfil
#10 Posted : 10 May 2019 01:08:25(UTC)
rhfil
Marklin has a computer app which allows you some access to your layout with a computer, smart phone or tablet. It is limited, for example the tablet allows you to control up to eight locos and all your coded items. However, it does not yet, as far as I can tell, show the actual layout. You need your Central Station to be connected to the internet. It takes some getting used to but might be fun at shows to allow bystanders to control a loco. Unfortunately it does not show the cab of mfx+ locos which would really get bystanders into the layout. Hopefully some day they will have a loco with a camera lens so that the operator will really be in the layout.
Offline MaerklinLife
#11 Posted : 10 May 2019 04:44:41(UTC)
MaerklinLife
Just FYI, you are reolying to a 6 year old topic.
Offline waorb
#12 Posted : 10 May 2019 14:23:59(UTC)
waorb
Brazil
Besides of the age of the original post, the loco with cams was already on the market, and discontinued as well...
RollEyes
Marklin Mobile Vision
Walter
Offline michelvr
#13 Posted : 10 May 2019 15:09:00(UTC)
michelvr
Just FYI, you are replying to a 6 year old topic.
My oh my, time certainly flies by.........Blushing
2013 that was my second year into Märklin model trains and I do recall I was using TouchCab on my iPhone controlling my trains from the ECoS. All that was required was a router. Worked great!
What about today? Not sure as my layout is being rebuilt and I haven't had the pleasure to run my trains. Hoping TouchCab is still active. Anyone know?
Offline dickinsonj
#14 Posted : 10 May 2019 16:39:45(UTC)
TouchCab is still available in Apple's app store.
I still use Märklin's MainStation on a tablet and MobileStation on my phone, both of which work quite well. I use a CS2 and do almost all of my control via the MainStation app. The graphics and response speed are far superior to using the CS2 itself. I'm not sure if these work with the CS3 or not, but Märklin is moving to allow full control via your browser which I hear works great.
Guest (10)
This page was generated in 0.481 seconds.
