Hello, I got recently a CCS 800 that is a little puzzling to me because it seems to have couplings and pantographs from different dates and both are most certainly the original ones! It has the so called BK4.2, that were delivered only till about 52? but it has the small nickel plated pantographs including the green plastic insulators that were delivered maybe only after 55? Another surprise with the pantographs is that they are fixed with a screw and nut on the inside, never seem before. I am convinced that the pantographs are original with the plastic insulators, because when I un-mounted them the plastic was "glued" to the paint, and it does not seem that others were mounted before. The schleifers are the normal sky type with large hole, they seem original also. The loco has the two touch reversing mechanism that controls also the lights. So what is the best guess for the year of manufacture of this machine? 53?? And is it also normal to see the type 6 pantographs fixed with screw and nut and not just a screw from the inside? I am sorry but I am not able to upload some photos, I am with a slow connection... but maybe you can help anyhow? Best regards Manuel
Hello Manuel,
Is the "CCS 800" lettering on the cab painted silver or gold or something else? According to your description, I think it is a version 7.
Paul |
Joined: 01/03/2008(UTC) Posts: 2,883 Location: South Western France
Originally Posted by: mpipa  Hello, ....is it also normal to see the type 6 pantographs fixed with screw and nut and not just a screw from the inside?
Hello Manuel As far as I know, the pantographs were always mounted from the inside (except on the DL, ST, that were "convertible" diesel or electric) That's a puzzle... Now your pantographs should normally be the copper type( up to 1954 I think), no green insulator. I can only speculate for these apparent "contradictions" but during my Märklin repairman career, I have seen many puzzles! So here's what I think happened: A previous owner may have decided to renew the original (copper, no green plastic) pantographs, sometimes after 1954, when the copper ones got no longer produced Maybe they were broken or simply worn out... The newer version was compatible, a little smaller than the copper ones, to compensate for the couple of mm added by the plastic insulator. But whomever did the replacement discovered that opening and re-assembling a crocodile was no pic-nic...so to facilitate subsequent replacement, used longer screws, drilled out the threads of the pantographs and made them assembled from the outside, using a nut. Maybe just my imagination, but I'm ready to bet it is something similar! Hope this helps solve the "riddle of the crocodile"! |
Jacques Vuye aka Dr.Eisenbahn Once a vandal, learned to be better and had great success! |
Originally Posted by: jvuye  Originally Posted by: mpipa  Hello, ....is it also normal to see the type 6 pantographs fixed with screw and nut and not just a screw from the inside?
Hello Manuel As far as I know, the pantographs were always mounted from the inside (except on the DL, ST, that were "convertible" diesel or electric) That's a puzzle... Now your pantographs should normally be the copper type( up to 1954 I think), no green insulator. I can only speculate for these apparent "contradictions" but during my Märklin repairman career, I have seen many puzzles! So here's what I think happened: A previous owner may have decided to renew the original (copper, no green plastic) pantographs, sometimes after 1954, when the copper ones got no longer produced Maybe they were broken or simply worn out... The newer version was compatible, a little smaller than the copper ones, to compensate for the couple of mm added by the plastic insulator. But whomever did the replacement discovered that opening and re-assembling a crocodile was no pic-nic...so to facilitate subsequent replacement, used longer screws, drilled out the threads of the pantographs and made them assembled from the outside, using a nut. Maybe just my imagination, but I'm ready to bet it is something similar! Hope this helps solve the "riddle of the crocodile"! Jacques, I think your theory might be correct about the pantographs, but if they were supposed to be copper pantographs, then would the CCS800 in that version have the tongue-type pickup shoe "Bogenschleifer" from 1951-1953. In my opinion, it is much more difficult to replace a pickup shoe than a pantograph so I would judge the version based on the pickup shoes more than the pantographs. Although the transition from the solid rails to the studded rails might have required the owner to upgrade pickup shoes....it is really hard to say without a photo! My guess is still Version 6/7. Best regards, Paul |
Paul
Yes Paul, agreed! From that solid rail/ studs transition era , many locos have lost their original "Löffelschleifers", had pantos replaced, wheels with traction tyres fitted, and later two stroke inversion relays replaced with single-stroke ones as well. My very own 1951 RSM 800, my very first lok, went through all these motions...and then some The good news is that these parts can be replaced with Ritter's productions, and returned to "original" condition. Cheers |
Thanks for the replies.... Sorry for not adding the photos, but I can add that the CCS800 is blank (no paint), and it is dark green, not olive. Besides the intriguing screw and nut on the pantographs, and since I read somewhere that the BK4.2 couplings were possible up to 56, this is probably a version of that year, it is also compatible with the pick up shoes. And also it seems that the small type 6 pantographs were mounted with green plastic insulators after 55? When I un-mounted the pantographs to clean them, the plastic insulators were glued to the paint, and I am convinced that they were never removed before. Is this some original mounting from the early times of this type of pantographs, later changed for the regular one? So... ha sanyone else seem such a way of mounting this pantographs? Regards, Manuel
I've never seen pantographs for a CCS800 mounted that way. Considering that the housing is threaded, I would see no need for a nut. In this case, I think the threading could have stripped and a nut was used instead.
I must also add that it could be a CCS800 Version 8 depending on how it is painted. I was previously looking at a version of Koll's that is 30 years old and they didn't make the distinction of Version 8.
If the "CCS 800" is painted silver on a black background and the shells are "dunkelgrun" Dark Green, I think it is Version 7.
Paul |
Originally Posted by: mpipa  Thanks for the replies.... Sorry for not adding the photos, but I can add that the CCS800 is blank (no paint), and it is dark green, not olive. Besides the intriguing screw and nut on the pantographs, and since I read somewhere that the BK4.2 couplings were possible up to 56, this is probably a version of that year, it is also compatible with the pick up shoes. And also it seems that the small type 6 pantographs were mounted with green plastic insulators after 55? When I un-mounted the pantographs to clean them, the plastic insulators were glued to the paint, and I am convinced that they were never removed before. Is this some original mounting from the early times of this type of pantographs, later changed for the regular one? So... ha sanyone else seem such a way of mounting this pantographs? Regards, Manuel Ola Manuel! Never did I see the pantographs mounted like that on a ccs 800, but does it matter?? My take on this is simple: users do things to their loks in good faith, not always thinking of preserving "originality" but rather enhancing functionality (and the CC was a real pain to work on!!!) So there is probably no point trying to solve a riddle.. The insulators are glued? So what does it prove?? It was never a factory privilege to do so! Why would'nt an intelligent private person think of simplifying his life saying: "this will work better"? It may even never have been glued: the original paint aging can produce exactly the same effect... I have seen time and again on many locos in the 60 odd years I have worked on Märklin engines! If the owner decided it was better to do that, and simplify his life with subsequent pantograph changes,more power to him! The key is that he did it properly without unrepearably butchering the loco! Without at least a few pics we won't be able to tell you what really happened...but is it important? The engine is not disfigured, is it? I think the color of the marking (gold, silver, etc) like Paul suggests is a much more telling indicator. And if you'd like to do so , after we determine exactly which year your loc is from, there is no obstacle to bring it back to 100% original-like. Relax, we are here to help! |
Hello Paul, Jacques, So it seems that no one has seen this mounting before and it does not seem likely to be original... I am sorry for being more curious than others with this issue, but I though it could be interesting to other collectors if it would be a factory variation, as a collector I like to find and discuss new things.... Off course I was not saying that glue was used, I was saying that the plastic was glued, like Jacques says by a reaction with the paint. Since there were no marks of different "gluings", I was concluding that the pantographs were factory mounted, but is also possible, and more likely because no one has seen this srew-nut mounting that the previous owner has changed the pantographs at an early age, and since them the gluing process has developed. It is realy a shame that I can not upload photos with the connection I have here, sorry... but you have all been a good help Best wishes, Manuel
Originally Posted by: mpipa  Hello Paul, Jacques, So it seems that no one has seen this mounting before and it does not seem likely to be original... I am sorry for being more curious than others with this issue, but I though it could be interesting to other collectors if it would be a factory variation, as a collector I like to find and discuss new things.... Off course I was not saying that glue was used, I was saying that the plastic was glued, like Jacques says by a reaction with the paint. Since there were no marks of different "gluings", I was concluding that the pantographs were factory mounted, but is also possible, and more likely because no one has seen this srew-nut mounting that the previous owner has changed the pantographs at an early age, and since them the gluing process has developed. It is realy a shame that I can not upload photos with the connection I have here, sorry... but you have all been a good help Best wishes, Manuel Hi Manuel If you asked me, that is the way I would have mounted the pantographs anyway on any Märklin locos from that era! Changing anything like brushes, bulbs, inversion relays, pantographs etc. was such a pain in those days( too many screws, too many loose wires!!) that any chance to simplify would have been welcome. In fact in my early days with Märklin (early 1950's) it was always dreadful to have anything done! I had to bring my (only) loco to the dealer, and it would usually consume all my weekly allowance, just to change a bulb! That is why I decided to learn to do it myself...and for my friends at school who were in the same predicament. After I was able to fix an RE 800 that the dealer had given up on, I knew I had something going for me! This is how I started collecting Märklin: when my friends at school got tired of playing with their trains, and after I had repaired them too many times to their taste, they ended up selling them to me...! There is, so far, no Marklin lok from that era that cannot be repaired! Cheers |
