Offline HLL
#1 Posted : 20 May 2011 21:39:17(UTC)
HLL
Hi there.
My 2 Digital locomotives have no headlights at all when I run them on the Delta 6604. My Delta Locomotives have lights.
I have set the address to the correct Delta address and they run just fine.
According to the instructions the regular headlights should work in the direction of travel...
Is this normal?
Thanks.
#2 Posted : 20 May 2011 22:15:17(UTC)
Originally Posted by: HLL Go to Quoted Post
Hi there.
Is this normal?
Thanks.
Which decoders do the digital locos have?
#3 Posted : 20 May 2011 22:32:18(UTC)
If you have a 6021 or CS or MS, try activating the Function button and then place the lok back on the Delta circuit. Do the lights still not work?
If the Loks are older 36XX numbers, they were designed with lights that did not function in analog mode. I am not sure whether they would work in Delta operation, as they have to be activated in digital use for them to work. I think that those were 6080 or older decoders. Delta works pretty much the same as on the digital system, only there are no functions and only 4 selectable addresses.
#4 Posted : 20 May 2011 23:26:47(UTC)
Is this normal?
Yes, this is normal.
You need a Delta 66045 (or a modified 6604) to turn the lights on and off.
Required modifications for 6604:
http://www.marklin.com/t...gital1/images/6604+.jpeg
Offline HLL
#5 Posted : 21 May 2011 08:46:13(UTC)
HLL
I'm not sure which decoders are in my 2 locomotives. They are from the 29859 Digital starter set. Circa 2001.
I will try to take them to a setup with the Digital controller and switch on the lights.
Thanks for the advise. :)
Online gerardo960
#6 Posted : 21 May 2011 16:25:11(UTC)
gerardo960
Argentina
Hi I have a locomotive has a decoder installed Delta No. 6604 but when operating in digital mode the lights have been permanently predation would like to know how you can turn off and when starting the engine enced as well work on other machines.
#7 Posted : 21 May 2011 18:32:38(UTC)
The 29859 Set came with a 6021 Control Center. Why are you using the basic Delta controller instead of this digital unit? Any lok that will work on Delta will also work with the corresponding digital address.
I will do some tests with my loks from the same set with a surplus delta controller that I have here and will report back to the forum.
#8 Posted : 21 May 2011 19:16:27(UTC)
The 6080 and 6090 decoders will run with lights off in analogue mode. I believe the 6604 delta controller will run these locos with the lights off as well. 60901 decoders were the first to allow lights to stay on in analogue mode.
If you wish to continue to operate with a delta controller you can find many 66045 controllers at quite low prices. The 66045 allows you to switch lights on and off on all digital locos.
#9 Posted : 21 May 2011 20:09:06(UTC)
Hi HLL,
Welcome to the forum.
#10 Posted : 21 May 2011 22:03:12(UTC)
That is correct.
But when running with a DC 6604, the lights will be off, even with the 60901 decoders. Delta is digital, not analogue mode.
When using a Delta Station 6607, lights will be on - with 6080, 6090, and 60901 decoders.
"Function" and "off" are not always used for lights, some early locos used it for Telex. Those locos couldn't be used with a DC 6604 if function was always on (they can't be used with a 6607, but that was primarily designed for I gauge).
Welcome to the simple world of Märklin.
#11 Posted : 21 May 2011 22:44:47(UTC)
Older digital locos have the "lights off" as the default setting - meaning they need to be activated by a "real" (read - more expensive) digital controller. The 6604 Delta does not have the ability to control any digital function, nor will the light work in analog operation, unfortunately.
The latest Delta controller had a function on/off, as well as the latest Delta decoder boards with 80 settable addresses (just before the mfx protocol was introduced).
Newer full digital loks (2003-5??? -> onwards) have "lights on" as default, I believe... They did a rethink and enabled the function since many analog users were a bit "upset" that the lights didn't work...
I remember being very displeased with the fact that the lights did not work on my 3791 BR 03.10 when I bought it in the 90's, but I caved in and got myself a 6021 and went digital...
#12 Posted : 21 May 2011 23:20:10(UTC)
Yes and no.
Yes for analogue mode, no for digital mode.
This thread was about digital mode using a Delta Control 6604 originally.
Offline HLL
#13 Posted : 22 May 2011 10:11:15(UTC)
HLL
Thanks to everyone for all this information.
I only have the 6604 & 6647 set-up at my place. My friend has the 6021.
Have not yet decided if I should get a digital controller. I think the 00748 controller is cheap now and it can control lights - but that is only 18va. Dunno if I can use it to power 3 trains at once. Dunno if I can use my 6647 to power the 00748 either. Or if the power supply with the 00748 allows analog turnouts & a 7272 to be plugged in. I could use the 6647 to power the turnouts only and then have a big mess of controllers and wiring.
If I got a 60653 that would not be cheap as I would then have an excuse to get digital decoders for my turnouts. And I already spent a load of time soldering wire extensions onto my 77490 mechanisms.
Wow, so complicated...Confused
#14 Posted : 22 May 2011 10:29:41(UTC)
If you have more than 4 turnouts, better don't try to control them with an MS2.
So keep the turnouts as they are if you go for an MS2.
A 66045 would be an improvement over your 6604 (I bought some for Euro 1,00 on eBay).
The 00748 would give you more options, but it has neither speed knob nor speed indicator. Good for a short test, but I don't think I could use it to control a layout.
OTOH it can be used to change the addresses of new locos (which cannot be done with a Delta Control).
#15 Posted : 22 May 2011 11:02:08(UTC)
Don't allow others to dictate the way you run your layout!
I entered the digital world myself with a delta setup. I was aiming at getting a starter set with the 6604 delta controller, but in the end the set they had at the shop I went to had the latest (at the time) 66045, which was even better as it allowed control of the lights on digital locos.
When I joined the forum I felt under enormous pressure to get the latest and best digital control, but I felt it didn't suit the way I like to play with my trains. After a couple of years I got a good deal on a 6021 controller, which was really easy to integrate in place of my 66045. I use it to run the trains, and I operate the turnouts and accessories with old fashioned control boxes. The 6021 gave me more digital addresses available to use, and also access to the main functions on locos. I don't plan to extend the system with digital accessory control, computer control, routes, etc, because I don't feel they will add anything to my enjoyment of my trains. Others, of course, will disagree, which is fine!
My point is, decide for yourself what will work for you. Don't feel under pressure to get a really expensive controller which may or may not be what you really need.
This page was generated in 2.344 seconds.
