Offline rhobson1968
#1 Posted : 28 April 2010 06:08:23(UTC)
rhobson1968
I bought a new vintage marklin M track turntable. Problem is I have C track. Besides getting the C to M track convertor tracks has anyone done any crazy stuff to make a turntable M track work with C track.ThumpUp ThumpUp .. I was thinking of cutting the tabs off of the end pieces and setting them against the turntable and running seperate power to the turntable.
Never quit building.
Offline ac jacko
#2 Posted : 28 April 2010 11:21:15(UTC)
ac jacko
Good on you as the ones I have seen are very dear to buy. Where did you purchase from?
Offline Philip
#3 Posted : 28 April 2010 15:34:28(UTC)
Philip
Hello.
I would choose to use the convertor tracks between c-rails as to and from the turntable and otherwise use m-rails for train depot tracks.
Philip.
Let's keep it simple.
MFDWPL
Offline rhobson1968
#4 Posted : 29 April 2010 20:30:59(UTC)
rhobson1968
The idea of using M track in the depot is what I will do. I was thinking inside the box when I needed to think outside. I have enough M track to pull it off and a couple of C to M will do the rest. ...
I bought the turntable on EBay. It was listed as non-working but once I got it and cleaned it it was perfect again.
Offline Deborail
#5 Posted : 26 May 2010 15:49:31(UTC)
Deborail
United Arab Emirates
A turntable is an interesting addition, but would it be large enough to accomodate a big boy (465mm)? Also would it be able to work with Hornby 2 rail DC rails feeding to it?? The 7286 marklin turntable is around 300 Euros...
George
Given enough time, tasks manage themselves.
#6 Posted : 26 May 2010 16:04:30(UTC)
George,
I reckon you'd be better off getting the Fleischmann turntable.
BTW, I don't think any turntable would fit a BigBoy!
#7 Posted : 26 May 2010 17:06:39(UTC)
Märklin 7286 is the Fleischmann turntable (3-rail version). 2-rail version available from Fleischmann (that's what Ray meant).
Too short for a Big Boy.
Roco also offers a turntable (for 2-rail and 3-rail).
I don't have experience with any of those ... Sad
UP had turntables big enough for a Big Boy.
But I never heard of any H0 model of those.
#8 Posted : 26 May 2010 18:06:52(UTC)
Deborail wrote:
.....but would it be large enough to accomodate a big boy (465mm)?
Marklin strongly advise against trying to turn a 7286 turntable with a Big Boy on the table, as the locomotive is too heavy for the motor in the turntable. You can run a BB through the table, but should not attempt to turn a BB.
Offline dntower85
#9 Posted : 26 May 2010 18:15:52(UTC)
dntower85
there were only a few turn tables large enough for the big boy. here is one
Cheyenne, WY‎
An large engine shed can be set up so the big boy can pass across the turn table with out tuning it.
in most cases i think the big boy was turned on a large wYe.
DT
Offline sudibarba
#10 Posted : 28 May 2010 02:51:38(UTC)
sudibarba
I have one 7186 on my layout and 2 in reserve. They are loud but who cares (my view anyway). Hook up the coverter track and get M track for the out feeds. Just as good a C track for that purpose. I don't think a Big Boy would ever fit in any shed.
Eric
#11 Posted : 28 May 2010 12:14:47(UTC)
Where did you read that?
They say the Big Boy can ride over the turntable, but cannot be turned.
But they don't say why in the product database.
I simply presumed that one cannot turn a 46 cm loco on a 31 cm turntable. But maybe this explanation is too simple and too obvious, and weight is the real problem ... Scared
Offline jonquinn
#12 Posted : 28 May 2010 21:53:13(UTC)
jonquinn
I think maybe the only HO turntable that might work with a BigBoy is the Walthers/Heljan(?) 130' table. I don't think they are so common on ebay lately, and they are kind of pricey. I saw one work at an NMRA train show a few years ago, and it did appear to run pretty smoothly, and indexing was precise.
you would of course have to figure out how to convert the bridge to work with 3-rail track. PierreGillard did a conversion to one of the walthers 75' TTs some time back.
Offline christos563
#13 Posted : 03 March 2015 19:25:40(UTC)
christos563
Hi mister and any other friends form America,
Hi from thessaloniki, hellas.
The turntable will Work with 24951 adjustment track. Big boy and Penny PA-1 can only Cross the turntable, not change face on it.
My greetings and good afternoon.
Christos563.
thanks 1 user liked this useful post by christos563
#14 Posted : 03 March 2015 20:57:11(UTC)
I'm fairly sure I read it someone, maybe in a Marklin Magazine. But after 5 years I can't really remember exactly! However, it stands to reason that weight would be the reason if Marklin tells you not to turn a big heavy loco like a Big Boy on their turntables.
#15 Posted : 04 March 2015 08:16:15(UTC)
IMHO it is more important that the Big Boy is much longer than the turntable. You have to turn the Big Boy in two halves to make it work. LOL
The Big Boy is 46 cm long, the turntable has about 30 cm.
The Big Boy can drive across the turntable, but it cannot be turned.
Offline biedmatt
#16 Posted : 04 March 2015 13:36:26(UTC)
biedmatt
The BR 53 with the water condensing tender is also too long for the M turntable. There are a few situations (2?) where opposite tracks will line up and you can run the 53K or BB through the turntable, but if you try to turn them, you will be left with loko both on and off the turntable. Might be interesting to watch once, in a Gomez Adams way.
Matt
Era 3
#17 Posted : 05 March 2015 01:57:37(UTC)
I think I already said that, five years ago!
Offline biedmatt
#18 Posted : 05 March 2015 02:30:08(UTC)
biedmatt
Hi David,
I missed that post five years ago. Based on your posts in this current thread, I, and perhaps others, was left with the impression you felt the limiting factor was the weight and not the length.
Matt
Era 3
#19 Posted : 05 March 2015 10:49:45(UTC)
Possibly, but the point I was trying to make was that Marklin had said not to try to turn the BB on a turntable. Whether it was because of length or weight I don't really remember. I must admit that I've never tried to measure the length of either of my Big Boys, but whether the reason for not turning the Big Boy is because of weight or length, or most likely both, is a moot point. The important point is, don't do it!
#20 Posted : 05 March 2015 11:48:37(UTC)
You wrote about big heavy locos in general, not about the Big Boy.
If length is the limiting factor then it's easy to tell what goes.
If weight is the limiting factor then where is the limit?
From the Big Boy product description: "The track must be well mounted due to the heavy weight of the locomotive. The locomotive can only be run through a turntable or transfer table."
I think length is the only limiting factor with respect to turntables, but weight can be a problem with bridges and other constructions.
#21 Posted : 06 March 2015 11:01:02(UTC)
That was probably where I got the idea weight was an issue.
This page was generated in 1.051 seconds.
