Offline ksor
#1 Posted : 14 November 2009 18:31:25(UTC)
ksor
I have a loc with this docoder and it runs in all aspects perfect, BUT when running into the BRAKE-section on Märklin braking the ligths turns OFF and the lights comes ON again when NO BRAKING appeares.
When the loc stands still on the track I can turn the lights ON/OFF with F0 and FOff as useal.
What can be wrong here ?
KSor,
#2 Posted : 10 December 2009 15:01:41(UTC)
Ksor,
I have the same decoders but haven't found a problem with the lights.
Could it be the decoder is not compatible with the braking module ?
regards.,
Offline ksor
#3 Posted : 11 December 2009 07:37:23(UTC)
ksor
I too have other locs with that decoder with NO PROBLEMs !
But maybe the problem is solved !
In this particular loc I re-used the lamps from the original setup with the chassis from the loc as common - maybe it SHOULD be the common from the decoder instead !
But I haven't got the time to try it yet !
KSor,
#4 Posted : 11 December 2009 08:17:52(UTC)
Should be ok to try, as long as you isolate the common connection to the lights from the chassis.
#5 Posted : 11 December 2009 12:18:57(UTC)
blue = neutral
black = common
red = track
orange = motor
grey = motor
green = Aux 1
violet = Aux 2
white = light front
yellow = light back
follow instructions as BDNZ
regards.,
#6 Posted : 11 December 2009 15:08:30(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by river6109
<br />blue = neutral
Blue is common plus for all decoder functions.
http://www.litchfieldsta...pix/SelectHarness-7a.jpg
http://www.litchfieldsta...ersity/SelectHarness.htm
This page was generated in 0.307 seconds.
