Offline Hobbit
#1 Posted : 06 October 2009 08:50:51(UTC)
Hobbit
I am experimenting with the generic steam sound project which I downloaded from the ESU site into a LokSound v3.5 decoder. I manged to get it working except for one small detail; when I tried to synchronise the chuffs to the wheel revolutions I could not follow the instructions in the manual as I cannot get any chuffs happening at speed step 1. The loco moves but it does not chuff. I can however get chuff at all other speeds.
I managed to get a reasonable synchronisation using speed steps 2 and 3 instead of 1 and 2 so that is ok, but what do I have to do to get chuffs at speed 1?
There is no place like The Shire...
Offline Lollo
#2 Posted : 06 October 2009 13:44:26(UTC)
Lollo
Hi Hobbit,
Check that CV57 is not set to 0. Default for steam is 20.
If set at 0 it is expecting trigger from a wheel sensor.
0 is also default for Diesel.
This info below from Loksound manual V3.5
cv57.
Sound mode 1 Multiplied by 0,64 is the time in seconds 0-127
between two chuff sounds at speed step 1.
Value 0 indicates that period between LokSound
exhaust chuffs is controlled by a wheel sensor
Steam: 20 Diesel: 0
Brian.
Brian
Yaasan's Desktop Station/Railuino & Marklin MS2, DB Era III/IV Diesel & Steam, ESU Loksound/Lokpilot & Lokprogrammer, Marklin mSD, Tam Valley Depot Octopus III Servo Controller.
Offline Hobbit
#3 Posted : 06 October 2009 15:42:51(UTC)
Hobbit
For the best synchronisation I had to set CV57 to 42 for the 3 cylider BR01 and CV is also set to 42.
The speed curve is set to manual 28 steps. Step 1 has a value of 1, Step 2 = 2, 28 = 140
#4 Posted : 06 October 2009 16:49:38(UTC)
BR 01 has two cylinders (four chuffs per rotation).
BR 01.10 has three cylinders (six chuffs per rotation).
Offline Hobbit
#5 Posted : 07 October 2009 06:01:50(UTC)
Hobbit
Thanks. I meant to write BR01.10. So I will change it to six instead of three chuffs by halving the value in CV57.
Still leaves the problem with no chuffing at speed step 1.
Offline cyberbeast41
#6 Posted : 07 October 2009 11:08:23(UTC)
cyberbeast41
Is there chuffing at very low speed in real life?
[size=1" face="Verdana" id="quote]quote:Originally posted by Hobbit
<br />Thanks. I meant to write BR01.10. So I will change it to six instead of three chuffs by halving the value in CV57.
This page was generated in 0.552 seconds.
