Offline Gregor
#1 Posted : 14 March 2004 22:20:32(UTC)
Gregor
Hello All,
The head and tail lights of the Dutch/Swiss RAm TEE 1 feature one white and one red light bulb, which feed into a light conductor to illuminate the external lights. The white bulb should light all three lights, while the red bulb has a cover that should make sure that only 2 lights are lit, and that the top light remains dark when the red bulb is lit.
This does not work 100% to my satisfaction. The top red light is certainly much less bright than the two lower lights, but it is not completely dark.
Are there any tricks to improve this ? I use the train in both directions, so I can't use black paint to cover the top light.
Gregor
Offline franciscohg
#2 Posted : 15 March 2004 00:18:09(UTC)
franciscohg
Chile
Don't you have think about replace light bulbs with LED's?
There are very litle ones and if they don't fit the holes you can always polish them with the only caution of let the contacts not exposed.
Offline jorge_vilarrubi
#3 Posted : 15 March 2004 04:03:33(UTC)
jorge_vilarrubi
Hi Gregor, this is an old problem. You can try to reduce the brightness of the red lamp connecting a Zener diode in series with the lamp. The Zener voltage will be the tension you will reduce to the lamp, so you can try with 3V2 or 3V7, 6V3 etc. until you're satisfied.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline Gregor
#4 Posted : 16 March 2004 08:33:30(UTC)
Gregor
Thank you Francisco and Jorge,
I'll try the Zener first, the tail lights are too bright anyway. For Francisco's solution there is more courage needed than I currently have, so I will play with the thought for a while....
Gregor
Offline rugauger
#5 Posted : 17 March 2004 00:36:16(UTC)
rugauger
Very interesting. I have the exact same problem as Gregor with my 515/815 Triebwagen set (3028 + 4028). My idea was to cut the light conductor that leads up to the top headlight, mask the bottom half with dark paper or black insulating tape, and supply the top light with a separate light source (miniature bulb or white LED). I got as far as cutting the light conductor and then began to feel like Gregor - courage left me... [:(] Yet I'm still planning to come up with a more satisfactory solution - one day... Smile Maybe I'll trawl the M* spare part lists to see if M* themselves have developed something a bit more clever for one of their more recent products.
Richard
Offline Gregor
#6 Posted : 17 March 2004 12:21:31(UTC)
Gregor
Hi Richard,
Interesting solution, the challenge there is to match the colour and brightness of the top light with the two bottom lights. The white bulb would need to be replaced by a light similar to the top one, the intensity one could match using zeners or resistors.
Gregor
This page was generated in 0.263 seconds.
