Offline gachar001
#1 Posted : 11 March 2009 20:17:22(UTC)
gachar001
India
I have a 4367 SBB Eurocity 6 car set. This train derails on R1 curves on a slope. I noticed that the same 2 cars derail every time. I am wondering why this happens. I suspect that the coupling mechanism between these 2 cars do not move left to right smoothly and causes the train to derail.
If this is the problem, how can I fix this?
Thanks.
Gautham
Atlanta, GA USA
Offline rbw993
#2 Posted : 11 March 2009 20:20:27(UTC)
rbw993
Hi Gautham,
I'm not sure but that set might have adjustable buffers. Try and see if you can push them in. If one or more are too far ou they could snag.
Roger
Offline gachar001
#3 Posted : 11 March 2009 21:52:23(UTC)
gachar001
India
[size=1" face="Verdana" id="quote]quote:Originally posted by rbw993
<br />Hi Gautham,
Roger
I will check the buffers. Thanks.
Gautham
Atlanta, GA USA
#4 Posted : 11 March 2009 22:57:23(UTC)
I would agree with Roger's assessment of the buffers as being the likely source of the problem.
I do have a few questions that may assist your diagnostics:
If the same two coaches derail each time, what happens when you a) reverse the coaches 180 degrees, b) change the order in the train?
If the issue is the buffers, are all the buffers on your train pushed in or only some?
It is also possible that the metal piece that sits above the coupling shaft inside the problem coach is loose and is blocking the shaft from properly swinging to either side.
As the set contains two of the panorama coaches and two second class coaches, it should not be difficult to change the running order without affecting the consist as a whole.
Apm - Apm (Pano) - Apm (Pano) - WRm - Bpm - Bpm
In my set, I replaced one of the panorama coaches with a 4266 (Eurofima) coach, resulting in:
Am - Apm (Pano) - Apm - WRm - Bpm - Bpm
You can also add one 42162 or 42163 at the end as a Kurswagen.
The other panorama coach runs with my OBB EC Coaches as the "Transalpin".
Offline gachar001
#5 Posted : 12 March 2009 16:17:03(UTC)
gachar001
India
<br />I would agree with Roger's assessment of the buffers as being the likely source of the problem.
Thanks for the info Mike. I will experiment with it this weekend.
Gautham
Atlanta, GA USA
This page was generated in 0.362 seconds.
