Online jonas_sthlm
#1 Posted : 15 September 2009 00:30:20(UTC)
jonas_sthlm
its possible to download the new CS2 update with directly connected to the internet biggrin
with DCC support [:p]
http://www.modelltag.se/viewtop...&t=23&p=124#p124
My update went without any problems even for the booster Cool
#2 Posted : 15 September 2009 11:33:56(UTC)
DCC with dropdown for 14,28,126
MS now changed to MS1
No change to shutdown picture.
Web access looks like a mistake
From WebNews I have no idea what is referred to by ...
" More minutes, more power, and more comfortable locomotive selection are just three points of a comprehensive update."
Offline jeehring
#3 Posted : 15 September 2009 12:52:34(UTC)
jeehring
<br />DCC with dropdown for 14,28,126
Sorry, it's my English : Is "dropdown" a "dropdown menu" ?
MS changed to MS1...., good news , means the MS2 will come, surely !wink
#4 Posted : 15 September 2009 19:14:57(UTC)
Update sucessful 1.2.5 (1).
No sign of new locos icon yet.
Offline sudibarba
#5 Posted : 15 September 2009 19:15:11(UTC)
sudibarba
If I have no interest in DCC, should I update. Will I get more power in MM or MFX operations?
I suppose I should update just to keep current regardless, but should I wait and see for a while?
Eric
Offline Maxi
#6 Posted : 15 September 2009 20:25:03(UTC)
Maxi
Sometimes updating because a newer release is out is not always the right choice for all. In most cases it is nice to have the version which goes on the USB stick available on your computer, ready for updating and only update if your current setup requires a update to work properly. Otherwise you will not be gaining anything compared to what you were doing before. Sometimes the updateing will take a feature or type of functionality away, this would be rare. Also keep in mind that some updates can not be undone or downgraded, so decide carefully.
Offline villefra
#7 Posted : 16 September 2009 10:55:41(UTC)
villefra
A little sidetrack about "GFP". It seems like GFP (Gleis Format Prozessor) has been updated here. My assumption will be that the GFP SW module is the module that implements the low-level protocols, ie. the different versions of motorola format, mfx and DCC. So my assumption would be that GFP 1.23 is adding DCC, whereas GFP 1.22 did not have DCC?
BR Rasmus
This page was generated in 0.756 seconds.
