Offline billykatz
#1 Posted : 28 February 2026 21:22:56(UTC)
billykatz
I'm a recent entrant into the world of Z scale trains in general and Marklin Mini-Club in particular.
During this rather short learning curve I have been able to fry three Mini-Club steam locomotive motors. I very quickly discovered that replacement 3 or 5 pole motors for these engines were harder to find than hen's teeth, via Ebay, through dealers, or otherwise. I've read a number of forum discussions and it seems like Marklin is leaving their Z scale fans in the lurch and is no longer supporting their older products.
Apparently, the newer bell-can motors are the way to go, but Marklin doesn't seem interested in providing drop-in replacements or modification kits for their older engines. I've scoured the web and YouTube and came up with a bare minimum of information, none of which seem to be compatible with my older 3-pole steam locomotives.
I would guess that if a more experienced hobbyist has the answer or can come up with a work-around and makes it known, they might get nominated for sainthood by the Mini-Club community. If an enterprising person comes up with modification kits I think they might have a very tidy side business venture.
Finally, as a ham radio operator, it is almost part of the hobby for enthusiasts to dig into their equipment and repair, replace, or modify. For N scale there seems to be a decent amount of info on YouTube but Z scale repair doesn't get a lot of exposure. I can find more YouTube videos about watch repair, and that's even smaller than Z scale.
Please correct me or educate me if I am wrong about this, or share your thoughts. Much appreciated!
Offline ciderglider
#2 Posted : 28 February 2026 21:38:37(UTC)
ciderglider
My best suggestion is to find another model to cannibalize, and take the motor from that. Are you sure the motors are burned out? There's a good article on zscale.org about resuscitating z scale locos.
Edited by user 01 March 2026 17:06:53(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by ciderglider
Offline billykatz
#3 Posted : 28 February 2026 21:44:35(UTC)
billykatz
Thank you, ciderglider. I'll check it out.
Yep, pretty sure I toasted the armatures on all three of my locos. They're all shipped off to a repair service.
#4 Posted : 01 March 2026 09:51:12(UTC)
I'm curious how you managed to fry three in a row?
By your own admission about your 'learning curve' it seems you are aware that you may have done something wrong.
I can only imagne either the motor was stalled while power remained present, causing overheating and buring out of the winding, or, excess voltage above the 8-12v DC recommended.
Seems there's been a bit of variation with 10v DC becoming a defacto standard. Märklin shipped many starter sets with a controller that required only a 9v battery.
One advantage when testing etc is that by using a battery, your chances of high current drain are reduced, compared to a mains-powered contrller where rather high currents are possible in a dead-short.
Do you know for sure, or have a good idea what damaged your three?
Have you sent them to off to a specialist armature rewinding company?
Welcome to the forum by the way. Smile
Steve
Offline Chas
#5 Posted : 01 March 2026 15:48:14(UTC)
Chas
Try refining your internet search, loads of links from this site, as a suggestion
http://www.zscale.org/articles/revival.html
Hope you get on with Z gauge
thanks 1 user liked this useful post by Chas
Offline billykatz
#6 Posted : 01 March 2026 18:34:36(UTC)
billykatz
Thank you, cookie & Chas. Much appreciated!
I am aware of zscale.org, which is kinda how I screwed up my first locomotive. These engines are all at least 30 years old, so even NOS might be subject to congealed lubricant. The first engine was sort of pokey in performance. Following zscale's instructions, I carefully removed the bottom pan of the locomotive, put in a few drops of Labelle 108, reassembled the pan assembly, and then discovered one of the brushes had migrated to the outside of one of the wheels.
In trying to get it back in position, several driving wheels and their respective paired gears came out. zscale.org states: "Be very careful when doing this, as those tiny gears and wheels like to leap out. The copper contacts that touch some or all of wheels are spring-loaded; if you are dumb enough to remove one of those wheelsets (I speak from experience), you'll need to pinch the copper contacts against the chassis". After an attempt to stuff things in as accurately as I could, I decided I was over my head and packed it up to send it to Eurotrains in Stockton, CA.
Before I could mail the locomotive up to Eurotrains, I quickly burned out my two other engines through stupidity. I have a double-track setup in my office and had the trains running at low speed. I left the office for the day and forgot to turn off the controller. Apparently, both engines stalled and got their armatures toasted (I watched a YouTube video about the cardinal rules for model trains, the first being not to run trains unless you are there watching them). So those two locomotive got packed up with the first one and I shipped them all to Eurotrains for service.
Trial and error. And dumb mistakes. And maybe I'll learn a few things.
thanks 1 user liked this useful post by billykatz
#7 Posted : 02 March 2026 11:23:37(UTC)
Originally Posted by: billykatz Go to Quoted Post
...Trial and error. And dumb mistakes. And maybe I'll learn a few things.
Been there - done that and sadly still doing that. Crying
Offline Chas
#8 Posted : 02 March 2026 12:19:24(UTC)
Chas
Snap.
Offline Chas
#9 Posted : 02 March 2026 12:39:15(UTC)
Chas
If you are working on a small shunter 8800 etc ;, to quarter it loosen the screw of motor end of the pan slacken the front end there is enough wiggle room to quarter it (the connecting rods) and to pop the brush back behind the wheel. No need to take the pan off to get the brush in or quarter.
The big locos are a nightmare, try a long magnet over the side of the wheels, to keep the quartering
Chas
This page was generated in 0.365 seconds.
