Offline egonzinc
#1 Posted : 19 January 2026 20:16:19(UTC)
egonzinc
Puerto Rico
Before I start fooling around with the pieces, I’m tapping this forums brain power to see if this simple task has a ( hopefully) simple solution.
I include an image.
Want to do an exit with radius 5 and maintain a radius 4 parallel on the inside, as much as possible.
Offline rbw993
#2 Posted : 19 January 2026 21:44:28(UTC)
rbw993
What turnout are you planning to use?
#3 Posted : 19 January 2026 23:08:45(UTC)
Hi Eduardo
I would think something like this
Please replace the 2205 reference by 24430 one
What do you think?
Offline egonzinc
#4 Posted : 20 January 2026 00:00:37(UTC)
egonzinc
Puerto Rico
As soon as I posted, I started to play around with pieces or track and thought it would be impossible!
The end to the right is not 90 degrees from the beginning, but it will give some variety to the plan!
THANKS SO MUCH!
I rather use these turnouts, but I was wondering if there is a solution using the other turnouts, so it ends up at 90 degrees?
In another spot, similar situation, ending in 90 degrees would be preferable.
Conceivably use R3 and R4 radii instead of R4 and R5.
Again thanks so much for these designs
thanks 1 user liked this useful post by egonzinc
Offline egonzinc
#5 Posted : 20 January 2026 00:27:01(UTC)
egonzinc
Puerto Rico
This is the other problem spot.
The outer loop is R5 with some small straights added to go outside the pure R5 curve.
Need a “ get away” from the R5 loop.
#6 Posted : 20 January 2026 01:21:34(UTC)
You could try creating the outer curve using 24912, but at 1.1146m radius, it is quite a bit wider than R5.
Offline Ross
#7 Posted : 20 January 2026 02:36:39(UTC)
Ross
Hi Eduardo,
Another option for you to consider.
I include an image.
Ross
thanks 2 users liked this useful post by Ross
Offline Copenhagen
#8 Posted : 20 January 2026 09:31:30(UTC)
Copenhagen
About the second hand drawn sketch: is it the plan to have six curves inside each other (or five inside the outer track) on the layout?
Offline egonzinc
#9 Posted : 20 January 2026 15:31:07(UTC)
egonzinc
Puerto Rico
Not eventually. But the idea is to have one side with the loops and then have parallel tracks go to the right in annarea which will have minimalistic tracks.
I like to see the trains run. So I will use this “congested side” to set up trains and send them on a long run. Or to keep bysy in lical trafic.
Odd I know, but that is what I envision to do!
Offline egonzinc
#10 Posted : 20 January 2026 15:38:53(UTC)
egonzinc
Puerto Rico
Thanks Ross for your design. I really lijed tge “Jean Option”. Very clean and although it does not end at 90 degrees, it is clise enough to be manageable for that leg of the “fly away to the right”.
Now I need a solution for the other leg of the “fly to the right”.
I might use the same “Jean” solution, rotated 90 degrees clockwise… but maybe Hean or someone else can come up with another combination.
Thanks again to all!
Offline mbarreto
#11 Posted : 20 January 2026 15:58:47(UTC)
mbarreto
For the 90 degrees of R5+ you can have 24064 - 3x 24530 - 24064. It will work kind of R6.
Miguel
Mostly Märklin H0.
#12 Posted : 21 January 2026 00:39:04(UTC)
Also note that one of the track pieces Jean has used is a K-Track piece instead of a C-Track piece. You would need to identify the correct C-Track piece to replace it.
Offline egonzinc
#13 Posted : 21 January 2026 01:59:36(UTC)
egonzinc
Puerto Rico
Yes, noticed that. He did mention to insert a 24430. Have to get the pieces set up and see how it looks,
Offline egonzinc
#14 Posted : 21 January 2026 02:01:39(UTC)
egonzinc
Puerto Rico
Thanks for the suggestion. I have something similar now on that 5+ and it looks fine.
Offline PacoM
#15 Posted : 20 February 2026 14:40:42(UTC)
PacoM
THANKS SO MUCH!
Hello, I have seen your thread a bit late, but I think it is worth pointing out that there is a perfect solution al 90º.
I have shown beneath the simple design with R-3 an R-4, so that you can compare both sizes.
thanks 2 users liked this useful post by PacoM
Offline PacoM
#16 Posted : 20 February 2026 18:27:39(UTC)
PacoM
Or, if you do not like roadbed cutting beside the 24712, and prefer to use the orthodox 24071 standard pieces instead, this is the solution:
thanks 4 users liked this useful post by PacoM
Offline PacoM
#17 Posted : 20 February 2026 20:18:04(UTC)
PacoM
As to the branch to the right, these schemes may give ideas
Offline PacoM
#18 Posted : 20 February 2026 21:11:03(UTC)
PacoM
Always keeping the standard output separation between tracks
Offline Ross
#19 Posted : 21 February 2026 01:59:54(UTC)
Ross
Hi Francisco/ALL,
This is a variation trying to maintain standard spacing.
The example on the left is Francisco's design then the next two examples try and maintain standard spacing, I like the third example because the curves look reasonable.
The tolerances for track joins is set at 1mm.
Oh how I miss flex track.
Ross
Guest, polabear
This page was generated in 0.535 seconds.
