Offline jonas_sthlm
#1 Posted : 28 January 2026 14:06:57(UTC)
jonas_sthlm
Has anyone discovered a more advanced solution where the Uncoupling cycle is placed under the sound slot and can be activated like push button?
I haven’t come across any ESU project where they did anything besides using the Uncoupling cycle under Function Mapping linked to the button.
Of course, there’s always more to load since the sound and its settings are needed every time.
The idea is for the final sound step to happen automatically and for the button to switch to the off position.
When you turn off the function, the exit sound will play, but if you forget to turn it off, run the engine, and then stop, the locomotive will perform its dance move once again.
This page was generated in 0.201 seconds.
