Offline ddcullen
#1 Posted : 26 January 2026 08:11:24(UTC)
ddcullen
Video shows my loco struggling to stay moving smoothly. It starts and whines, chokes, sputtering. Ive properly oiled the gears. Not too much oil. Loco is practically new. Everything is clean on track and in loco. No grime, no rust. Electric current seems good. Other loco's run fine. Thoughts on what could cause the squeaking and poor running performance? Confused IMG_1452 (1).mov (10,600kb) downloaded 35 time(s).
Offline RudiC
#2 Posted : 26 January 2026 11:09:02(UTC)
RudiC
That sound and the simultaneous stutter to me indicates a mechanical problem. What motor does it have? Pls give us the Märklin article number as well.
Rüdiger (Rudi)
#3 Posted : 26 January 2026 11:34:37(UTC)
The loco makes clearly a sound of non-lubricated mechanism.
The rough operation may also be caused by problematic current pick-up
Here is a video on how to service the SchienenZeppelin
Clean the mechanism using NOCH SR24 or equivalent
Then lubricate using Märklin oil using a serynge sparingly but on all bearings (Motor, awles) and a bit of Trix/Märklin grease on gears VERY LITTLE.
Brushes and brush holder must be clean
UNLIKE shown on the video the inter-collector gaps must be cleaned using a toothpick NOT a knife
Offline ddcullen
#4 Posted : 26 January 2026 16:47:08(UTC)
ddcullen
Ya thanks. I’ll recheck the pick up show. It’s fairly new Marklin 39777 (mfx). It certainly sounds like a mechanical problem, so I added Marklin branded loco oil to the gear spots. Not overdoing either. It’s clean. I was concerned it was a decoder issue.
Offline rhfil
#5 Posted : 26 January 2026 18:29:52(UTC)
rhfil
Can't tell if you have the same problem I had with a different model but you might try running the model with the cover off and watch the gear train. On mine the clip holding the gear train down was broken and when the engine moved a bit the gear train would lift off but then fall back down when the engine stopped moving. That may not be your issue but watching what happens to the motor might give you an answer.
#6 Posted : 26 January 2026 19:10:21(UTC)
Your model was released in 2021 for one year.
Its motorized bogie is the same since decades. The changes are a five pole motor and an MFX decoder.
It seems the decoder failure may be ruled out.
No wormgear issue here (there is none) only the noise of an axle rotating in its bearing with no oil
Also you may want to check / replace the brushes (E601460) They are standard one since decades and easily available.
The exploded view is here --> https://static.maerklin....9eec060c711632984276.pdf
Offline ccranium
#7 Posted : 26 January 2026 19:21:35(UTC)
ccranium
Thanks for this video, Jean! While 50 years old it's still a great primer on service for us analog die-hards. It also reminds me of why I convince my wife we need to buy cotton swabs/Q-Tips in bulk. RollEyes
And the best part (new for me anyway) is the quick view of the Trix 66626 grease which is still available on the M site. It's "Shell Gadus S2 V220 2" per the safety sheet, but I don't need a 14oz cartridge, so for the same price I can get it from lots of retailers.
Brian
Offline RudiC
#8 Posted : 26 January 2026 21:08:47(UTC)
RudiC
Originally Posted by: ddcullen Go to Quoted Post
I added Marklin branded loco oil to the gear spots. . . .
Do the gear spots include the motor axle? This, if running dry, gives that screeching sound. Try a droplet of oil / grease. Oil would go inside the bearing easier, but grease will last longer.
Rüdiger (Rudi)
This page was generated in 0.309 seconds.
