Offline Rocca
#1 Posted : 17 January 2026 18:37:35(UTC)
Rocca
Dear Märklin Friends,
I 've just put again in its operational condition my Märklin Digital Layout, controlled by a CS1. Well, I just reconnected these 2 Signals, which I switched only in analogue mode (red and green wires), because I do remember there were too many issues using them digitally. Anyway, for some reason I can't explain to myself, the Signal is constantly on "Stop" mode (red) e and I can't switch it to "go" (green). I've tried to take off the power of the Trafo, but I can't still now have any control on it. You must know that the layout has been inactive for many years. Any suggestion to make it switching back to "Go" will be very appreciated. The Lichtvorsignal is perfectly lighted on, but anyway it doesn't switch in the same way as the 76393,
Prof. Stefano Rocca
Online RudiC
#2 Posted : 17 January 2026 19:06:32(UTC)
RudiC
Some more info, please.
How is the signal connected / wired? What do you use to switch it? Did you check continuity of the coils? A little sketch might help, too.
Rüdiger (Rudi)
Offline Rocca
#3 Posted : 17 January 2026 21:39:33(UTC)
Rocca
Dear Rüdiger,
the wires are in such way: cables yellow and brown to the Analogue Märklin Trafo (light and O output); cables red and green to the O of the Analogue Trafo (white plastic case), but they're supposed to be connected to a 7072; the two red wires to B of the C-tracks (B). In such type of Signals where are the coils? I'ven't checked them because I do suppose there aren't any coils. Tomorrow mornng I'll bring a picture.
Stefano
Offline Rocca
#4 Posted : 17 January 2026 21:51:58(UTC)
Rocca
I've just found this:
https://www.manualslib.d...rklin-76393-1318527.html
but not useful because it speaks about digital wiring
Have a nice evening!
Offline klarinettmeister
#5 Posted : 17 January 2026 22:41:22(UTC)
klarinettmeister
Just go to Märklins homepage and search for the signal. There you'll find the manual for the signal with the analogue operation.
There's only one coil which is the relay for turning on/off the power to the track/catenary. The red and green cables are supposed to be connected to 72720. 72720 gives a short impulse to one of the contacts to switch over from red to green or green to red.
Offline Rocca
#6 Posted : 18 January 2026 10:34:52(UTC)
Rocca
Dear KlarinetMeister, thanks! I've looked for the Booklet, but unfortunately there is only the one of the last version of the signal. Not mine. Anyway, this night, I'was thinking about connecting the yelllow cable for powering the Signal to the output of the CS1 instead of the analogue L output. What do you think in your knowledges?
Stefano
Online RudiC
#7 Posted : 18 January 2026 13:00:41(UTC)
RudiC
Originally Posted by: Rocca Go to Quoted Post
. . . cables red and green to the O of the Analogue Trafo (white plastic case), but they're supposed to be connected to a 7072; . . .
Your permanent connection of red and green to the Trafo's O- output might be the fault - connect only either, and only shortly (like 72720 or 7072 would do), to change the signal picture.
. . . In such type of Signals where are the coils? . . .
I have to apologize for my misconception; no coils, you are right.
Rüdiger (Rudi)
Offline Rocca
#8 Posted : 20 January 2026 18:45:15(UTC)
Rocca
Yesss, your suggestion is right, but, yes, I do never connect permanently the solenoids to the the 0 output! I do touch the 0 output very shortly. Anway, for some reason I can't explain to myself either, is the fact that, after having plugged the yellow cable from the signal to the CS1 and then go back to L output in the analogue Trafo I can switch it properly and it changes reguarlly to green or to red in the right way
Best regards!
Stefano
This page was generated in 0.331 seconds.
