Offline kaybee6
#1 Posted : 11 January 2026 22:33:19(UTC)
kaybee6
My BB 12000 has no reverse function. Lights and drive work fine in the other direction. I have a Mobile Station and my other locomotives seem to work as they should.
#2 Posted : 12 January 2026 12:24:34(UTC)
Hi @Kaybee6 (Is it Kay?)
My SNCF 12000 is a 37332 of 2003.
In my case:
- DC motor
- C90 type decoder (simulated adjustable inertia and speed adjustments
- an MM2 decoder
here is what I think:
- I am pretty sure your motor is DC (only 2 wires and in the vast majority of cases, if it runs one direction, it runs in the other
- the decoder MAY need ressting (depending on the type(C90 or later type). This is done writing CV8= 8. This solves many problems but alas probably not with the 37332 with a C90 decoder
- the other possibility is the decoder is fine except for the output stage of power transistors. They are arrange in H form to connect one of the motor wire to + and the other to - and modulating to control the speed. Big speech to say, if one transistor is dead then the motor rotates only in one direction.
What can you do?
- spares are unavailable
here is the exploded view SNCF BB12000
Here is the user's manual User's manual
The best is to replace the decoder by an MLD2 in cable tree form because there is not much space. Make sure that there is a resistor in series when wiring the headlamps (LEDs)
Adding sound to this beautiful loco would be very tricky (so better not)
Offline kaybee6
#3 Posted : 13 January 2026 04:33:05(UTC)
kaybee6
It is not the motor because the lights don’t work in that direction either. I can try resetting the decoder if my mobile station can do it. If that doesn’t work I’ll have to look for something wrong with the circuit board.
#4 Posted : 13 January 2026 10:57:17(UTC)
Either you can control (lights, speed, etc) the loco with your MS2 or not.
- if you can there is an issue with the decoder (not driving the motor in both directions)
- if you can't then need to double check the address set on switches (OFF and ON a few time for each of them, then a real address. Then ask the MS2 to search for a loco while IT IS ALONE on the track
The MS2 can write CV8=8 but I don't think the decoder (M90) will understand it (too old a generation)
If all the above fails, then you may have to replace the decoder (mLD2 wired, I think)
This page was generated in 0.376 seconds.
