Offline Dreadnought
#1 Posted : 02 December 2025 21:16:06(UTC)
Dreadnought
I am having an intermittent problem with the right wide curved switch. Some coaches, a silver liner, and a red double deck Regio car have problems on the switch.
It can happen in either direction. The red Regio control car lifts, but does not derail. I think it is the pickup shoe lifting on the frog. The silver liner it is the middle coach lifting at the frog and derailing. This is in push mode, not. A problem in pull.
Do i have a defective switch? This has not been a problem on the tighter curved switches, or on strait switches.
D
#2 Posted : 03 December 2025 00:29:25(UTC)
Hmmm.. very difficult to analyse the problem on these long turnouts.
Check the bogie wheels are sitting correctly in the bogie sides and are free running.
Check the back-to-back measurement of the wheels - impossible unless your have a vernier calipers or micrometer set.
Check the slider is not impinged in the sprung up-down movement or otherwise not in a normal attitude.
kimball
#3 Posted : 03 December 2025 08:59:34(UTC)
First thing to check is to observe whether the buffers of any of the coaches are impinging on the buffers of adjacent coaches.
You should also check to see whether a coupler is contacting the buffer of an adjacent coach.
The next thing you should check is whether the problem occurs in the same spot if you rotate one or more of the coaches by 180 degrees.
Is the Silberlinge (Silver Liner) a normal coach or a control coach (cab)?
The Red Doubledeck Regio coach is a pilot coach. Is the slider at the lead (cab) end or at the other end?
The slider exerts downward pressure. As it passes over the raised studs of the switch track, this can cause the bogie to be lifted off the rails.
In some cases, placing additional weights over the slider bogie can reduce this problem.
You should also check to see whether the slider is impinging on the coupler shaft. If this is the case, you may need to use a shorter or offset slider
Most Märklin coaches since the late-1970s have had had adjustable buffers.
It is rare that Märklin coaches have issues with their own close couplers, but if you find the coupler to be an issue, you can either try swapping one out for a regular coupler or use a different coupling that may work better with the buffers.
Coupler and buffer issues may not occur in regular curves, but may occur on switches and on S-curves depending on the track setup.
Offline PeFu
#4 Posted : 03 December 2025 16:35:46(UTC)
PeFu
I had similar problems, and after being recommended (somewhere), I ordered the following item. No problems anymore!
https://rztec.de/Shop/pr...n--24771-und-24772-.html
Smile
thanks 8 users liked this useful post by PeFu
Offline Bill L
#5 Posted : 04 December 2025 05:21:53(UTC)
Bill L
Hi PeFu:
I like your recommendation. This is the first time I have seen this item. I have never seen this before. Please describe how it works and what it does. Wondering if a similar item is produced for K track. 2269 double curve turnout has caused a lot of derailments for me. I have removed them from my layout.
Thanks PeFu for bringing new ideas for us to consider.
thanks 1 user liked this useful post by Bill L
Offline Dreadnought
#6 Posted : 05 December 2025 19:17:32(UTC)
Dreadnought
Thank you, PerFu,
I have asked my dealer to see if he can get these. My German is not good enough to order, and arrange delivery to Canada. Fingers crossed he can help.
D
Offline BenP
#7 Posted : 06 December 2025 12:16:56(UTC)
BenP
This looks like a potential 3D print project. Did perhaps anyone create stl files for m and c track switches?
Ben
Ben van der Pluijm--
Offline Dreadnought
#8 Posted : 20 December 2025 17:26:27(UTC)
Dreadnought
Good News!!!
It is fixed. My dealer found the isolator recommended by Perfu. He can order it. Before doing so he suggested i might have a defective switch.he gave me a new one to try. BINGO the new switch made all the difference. No more problem. The problem coaches run over it very smoothly.
My guess is that the tolerances on the wide switches are very tight, and the least flaw creates a problem.
D
thanks 4 users liked this useful post by Dreadnought
#9 Posted : 21 December 2025 20:49:14(UTC)
Originally Posted by: Dreadnought Go to Quoted Post
Good News!!!
D
That is a great result!
Online jonas_sthlm
#10 Posted : 21 December 2025 22:58:50(UTC)
jonas_sthlm
One thought I've had about the problem, isn't it just cutting heat shrink tubing? Huh
Maybe easier on the K-switch like I have.....
thanks 2 users liked this useful post by jonas_sthlm
#11 Posted : 22 December 2025 09:32:43(UTC)
Yes, I treated neuralgic PuKos with shrink tubing - see left and right of the screwdriver.
This page was generated in 0.699 seconds.
