Offline scraigen
#1 Posted : 19 November 2025 16:40:40(UTC)
scraigen
I've found myself dissappointed with MS1 and MS2's limited number of locos that can be stored, and am scared off by the cost of CS3.
Is there anything inbetween?
Must build something
#2 Posted : 19 November 2025 16:54:50(UTC)
CS3 is costly but will last for years and give you everything you need. Also it works well with Marklin items.
Better to spend on good control items which are essential. You could sell your MS to help with cost.
thanks 4 users liked this useful post by David Dewar
Offline mvd71
#3 Posted : 19 November 2025 18:31:28(UTC)
Is you don’t want the expense of the CS3, an option could be a used CS2.
If you want new, alternates are the ESU controller, or Uhlenbrock’s intellibox, of which there are two versions to cater for varying needs.
Offline osoraku
#4 Posted : 19 November 2025 18:59:10(UTC)
osoraku
Dear Stuart -
Another possibility is to run your locos using a computer and a train control program (e.g. Rocrail, but there are others). You can operate them using the gleisbox that comes along with your MS2 and some extra DIY hardware. This is not exactly an out-of-the-box solution, but it is cheap and then you are only limited by your train control software.
Examples discussed in this forum that I know of are the solution by the locoduino group for those facile with electronics and my own efforts involving less electronics knowhow.
Apologies if you've already considered and discarded this route.
Osoraku
thanks 2 users liked this useful post by osoraku
#5 Posted : 19 November 2025 21:27:28(UTC)
Views messages in topic : 15,594
The MS2 has a limit of 40 locos, but supports up to 10239 addresses. If you have more than 40 locos, you can work with loco cards, assuming that not more than 40 locos will ever be on the layout at the same time.
The old 6021 has a limit of 80 locos.
The Intellibox can handle 9999 addresses.
There are other options if you look beyond Märklin.
Online Goofy
#6 Posted : 19 November 2025 21:55:32(UTC)
MS2 are sucks sometimes because of the soft program which are dumb.
MS2 are depended of the CS3 to upgrade soft program.
MS2 don´t have program track output.
MS2 are bored to use but are friendly to use(sometimes).
Offline Martti Mäntylä
#7 Posted : 20 November 2025 03:02:27(UTC)
Martti Mäntylä
I concur. In addition, there are commercially available alternatives for hooking the Gleisbox to computer, such as the CAN Digital Bahn product suite that I am using.
I would not be able to run my trains the way I like it with a CS3.
- Martti M.
Online Goofy
#8 Posted : 20 November 2025 05:38:35(UTC)
Have you checked Pikos new start digital WLAN?
Anyway better than Märklins MS2.
You can download Pikos new WLAN to read and study before to buy it.
#9 Posted : 20 November 2025 07:20:15(UTC)
Bovine scatology.
So far, updates also come via CS2. Updates can be passed from MS2 to MS2. You can get updates from friends or from dealers.
If an MS2 is still limited to 11 locos, an update is long overdue.
Offline scraigen
#10 Posted : 20 November 2025 10:13:50(UTC)
scraigen
I checked the Marklin website before posing the question and it states "11 locomotives can be controlled with direct access." I took that to mean it will remember 11 that I program into it.
It's an option I would certainly consider, I might need help narrowing down the DIY choices as there seem to be a lot out there.
#11 Posted : 20 November 2025 11:25:47(UTC)
That's correct - but they show outdated information.
The German text reads: "40 Lokomotiven im Direktzugriff steuerbar*."
They forgot to update the English text in the product database. The actual limit is 40 locos as of version 3.55 and higher.
Offline scraigen
#12 Posted : 20 November 2025 14:30:46(UTC)
scraigen
Thanks, 40 locos is probably enough to satisfy my needs: which are basic control only. I just get fed up deleting and re-entering locos on the MS1.
I'll keep an eye on eBay for a 60657.
thanks 1 user liked this useful post by scraigen
#13 Posted : 20 November 2025 20:39:12(UTC)
MSL Will send a CS3 to the UK for about £460 and will add 3% bonus to your account. THis comes tax free so you take the chance of it coming through our customs free of VAT which although over the limit can happen and being busy near Christmas could help. Buying Marklin for Marklin items saves problems in the future amd mine is now about 10 years old and no problems.
Offline BenP
#14 Posted : 21 November 2025 17:13:32(UTC)
BenP
I have looked at options as I only need a passthrough box running Rocrail, but found nothing easy and inexpensive. I have used an old intellibox w rocrail, which worked perfectly fine, except no mfx recognition. Just assigned codes and working fine, including S88s feedbacks. However, the cs3 is just a better (but pricey) interface and has safety controls that protect devices.
Ben
Ben van der Pluijm--
Offline Pasquiles
#15 Posted : 21 November 2025 19:01:19(UTC)
Pasquiles
Luxembourg
I was reluctant once to buy the CS3, but know I must say I do not regret it at all. It is a huge step from the MS2.
thanks 1 user liked this useful post by Pasquiles
Online Goofy
#16 Posted : 22 November 2025 10:01:12(UTC)
Bovine scatology.
Nope!
I did had MS2 and when it was time to upgrade I was force to pay 5 euro to the dealer to upgrade via CS3.
It was that time before I did get a CS3.
I found out that MS2 are terrible by use so I did sold MS2.
If you want to upgrade standard MS2 from a WLAN MS2 you have to buy it because there are no WLAN at the store to support yours MS2 with upgrade soft program.
Online Goofy
#17 Posted : 22 November 2025 10:06:55(UTC)
Be attention about MS2!
If you shall change a locomotives value the loco must stand alone on the track.
It depends that MS2 are program on the main track too.
So that means you must use switch contact to alone track from the main track.
#18 Posted : 22 November 2025 19:49:29(UTC)
That's not true for mfx locos using mfx.
Offline dave55uk
#19 Posted : 23 November 2025 11:37:12(UTC)
dave55uk
Seems like several people don't like the MS2.
I do like it, as it enables me to move around the layout room
still controlling the train. A CS3 would mean I would have to sit
at a desk.
I am a one-man band though so controlling one train at a time
is enough for me.
thanks 3 users liked this useful post by dave55uk
#20 Posted : 23 November 2025 11:52:10(UTC)
I agree. I can't control more than two or maybe (after a can of coke) three locos manually. I only recently got the MS2 (and C track) to use for testing repaired locos, and while I don't find the MS2 very intuitive to use, after you read/study the manual it does work pretty well. It stores 40 locos, but it can be a bit of a challenge scrolling through the list to find the second loco before it crashes into the first one! In that case, I strongly recommend a second MS2 to control the second loco. I really don't recommend trying to run three locos manually on a small layout.
thanks 4 users liked this useful post by xxup
#21 Posted : 23 November 2025 12:14:59(UTC)
With one MS2 Hub 60122 you can use up to 6 MS2 with a single trackbox, allowing you to use more than 2 MS2s when running more than 2 trains at the same time or when performing complicated shunting tasks involving more than 2 locos.
Offline Copenhagen
#22 Posted : 23 November 2025 17:36:03(UTC)
Copenhagen
at a desk.
is enough for me.
The MS2 is fine for sure. I like the MS2 that I have connected to my CS3. With an extension cable the range can be increased if needed.
thanks 2 users liked this useful post by Copenhagen
Offline dave55uk
#23 Posted : 24 November 2025 01:19:37(UTC)
dave55uk
Now that's very interesting. Shame it's not made anymore.
#24 Posted : 24 November 2025 12:07:58(UTC)
It's made under the number 60145 now.
Unfortunately, that's not true.
60145 is the dark replacement for the 60125 terminal for any CS, but neither 60125 nor 60145 can be used with the MS2 trackbox.
60122 has no dark replacement yet. Some dealer may still have it. I bought one this year new from dealer.
Offline Copenhagen
#25 Posted : 24 November 2025 13:14:47(UTC)
Copenhagen
Oh yeah! Sorry for the misinformation. My mind was on connecting mobile stations to a central station...
Offline Pasquiles
#26 Posted : 24 November 2025 19:34:42(UTC)
Pasquiles
Luxembourg
at a desk.
is enough for me.
I also use the MS2 to control my trains, while connected to the CS3. It is very convenient.
thanks 2 users liked this useful post by Pasquiles
#27 Posted : 24 November 2025 21:39:27(UTC)
I think most of us likes the MS2, and the very few that doesn't uses every chance they get to tell us that they don't like it BigGrin
thanks 4 users liked this useful post by Purellum
#28 Posted : 25 November 2025 08:20:35(UTC)
I like the MS2.
I don't really like the CS3 and use (almost) every chance to mention that. Wink
Before buying an expensive controller, I highly recommend getting your hands on it and using it for a while.
The longer you are addicted to MRR, the more money you are willing to spend on a controller. So, sooner or later, the CS3 might be within the budget range.
When starting with MS2, the CS3 would be in the upgrade path. MS2 can be used with an ECos, too, but with limitations.
This page was generated in 0.795 seconds.
