Online BoBaCool
#1 Posted : 17 November 2025 10:26:01(UTC)
BoBaCool
Hi forum specialists !
By mistake I activated the MFX discovery in my CS2 keyboard menu.
Bad surprise : all switches/turnouts have been duplicated with new names and so on after the already configured switches.
Now that I understood what it is all about with MFX, I am trying to remove all switches/turnouts etc from my CS2 keyboard and start a clean discovery.
I did it by clicking one by one on the waste basket icon and started another MFX discovery but no way to move them all to the top at address one...
Any idea welcome, hoping that this would not require a complete reset to factory settings (if possible?) ... !
Thx,
-@ndré
#2 Posted : 17 November 2025 11:42:30(UTC)
Hi André
On the CS3 you need to clean all keybord entries that were created by the CS3 command "Look for new MFX devices", select each one and delete each one.
You may have to do some cleaning on the layout (Gleisbilder) side.
You must install again each entry of the m83 in conjunction with the switch settings
By now, the 60832 (m83) should respond to the MM2 or DCC commands as there is no RESET command available on the m83
Sure there are other ways to do things but the fact the m83s are screwed under the layout and harwired does not make it convenient for registrations (sometimes by accidents)
This page was generated in 0.316 seconds.
