#1 Posted : 15 November 2025 13:55:28(UTC)
Hey!
I have a question...is it possible to install cab lighting and connect as functional output?
Offline pederbc
#2 Posted : 16 November 2025 12:14:03(UTC)
pederbc
Hi Goofy,
Yes, I have done this on a couple of engines. You would of course need a decoder with spare outputs. Using ESU decoders I have set the rules to front: lights on, driving forward and engine not running and back: lights on, driving reverse and engine not running. The you can add some timing if you prefer. I found some leds designed for cabin light, a very small circuit board with led, resistor and soldered cables to be glued on the ceiling of the cabin. With the settings described the cabin light will turn on when the engine stops and only in the direction of travel. It’s a matter of finding a decoder with the extra outputs.
Most decoders only have Aux1 to aux4 powered, but the ESU ”MKL” versions also have Aux5 and 6 powered.
Peder
Offline pederbc
#3 Posted : 16 November 2025 16:40:27(UTC)
pederbc
Hi again,
Sorry, I didn’t read the heading. It seems that the engine is using, except lights, one for the smoke and two for the telex couplings. So there should possibly be one output left to be used for the cabin light. Do Märklin use msd3 decoders as original decoder in engines? Or is msd3 only for replacement?
Peder
#4 Posted : 16 November 2025 19:51:49(UTC)
The option I use is: stop forward and reverse as a function output (e.g. Aux 4 & Aux 5), neon lights with a delay of 3.96 sec., when the loco comes to a stop the interior cab lights come on, when the loco starts the delay of 3.96 sec. turns the interior lcab light off.
john
#5 Posted : 17 November 2025 18:41:52(UTC)
Originally Posted by: pederbc Go to Quoted Post
Hi again,
Peder
Exactly!
That´s way I did asked if there are AUX 4 to use it as cab light.
I have tried to figure out to see how PCB looks like and if there was a chance to install cab light.
Offline pederbc
#6 Posted : 17 November 2025 20:37:14(UTC)
pederbc
Is it a MTC21 connector? then Aux4 should be on one of the pins.
Peder
Offline bph
#7 Posted : 18 November 2025 13:34:48(UTC)
Hi again,
Peder
Exactly!
hi
On that locomotive, the AUX 2 should be free. The FGL couplers are using aux 3 and 4. But you need to verify that, eg check the AUX mapping of the locomotive.
Sometimes the unused aux has a free solder pad, but other times they have not, and you need to solder a wire to the pin of the MTC socket. (aux 2 is on pin 14)
This page was generated in 0.323 seconds.
