Offline Antonio Lopez P.
#1 Posted : 28 October 2025 21:50:07(UTC)
Antonio Lopez P.
Panama
Marklin 3021 test 1 Video 2025-10-28 at 15.35.04.mp4 (4,821kb) downloaded 38 time(s).
The beginning of the video is on forward mode, the lights turn on, but it doesn't move. Then when shifted to reverse, it moves but the lights don't turn on.
Before she was working fine, then I cleaned the motor and changed the brushes and the failure mentioned began to occur.
Does anyone have an idea of what could have happened? Help please, appreaciated in advanced.
Best regards, Antonio.
Offline marklin81
#2 Posted : 29 October 2025 01:47:42(UTC)
marklin81
Antonio, let me see if I can summarize your challenge:
1. In forward direction, you have lights but no movement
2. In reverse direction, you have movement but no lights.
3. Before you cleaned the motor, everything (motor and lights) worked as expected.
With movement in only one direction, I would check the continuity of wires between the reversing unit and the field coil. That's an old locomotive, and one of the solder points may have separated while you were cleaning. In particular, the point where the wires connect to the field coil or brushes may be loose.
Good luck and let us know what you find.
Pat
#3 Posted : 29 October 2025 02:37:41(UTC)
Antonio Lopez P.
Panama
Thank you Pat
Your summary is correct and will try your advise.
Yes, working with vintage is quite a challenge,
Let you know ofcourse outcome. Thanks again
Antonio
#4 Posted : 30 October 2025 18:19:08(UTC)
Antonio Lopez P.
Panama
Hello Pat
Further on your advise and further
1. All cables have continuity
2. Light bulbs and brushes are ok
3. Dismantled the motor and put back again. All in place
4. Gently with a tweezer tried cables welding and all are firm, none loose
5. Reverse module works remote and manually.
Will leave aside for couple of days and see what happends next. Works
sometimes with vintage locomotors, cargo and passenges wagons or until
new advises known.
Antonio
#5 Posted : 30 October 2025 18:21:35(UTC)
Antonio Lopez P.
Panama
Hello again
Left out to say. Locomotor still have the malfuction from the begining, althought all
done as per previous message
Antonio
Online RudiC
#6 Posted : 31 October 2025 09:24:32(UTC)
RudiC
Just for clarity: did you measure continuity between (farer away) motor brush (= field coil middle tap) and the two reverser contacts? Does continuity exist from slider to wheels in either reverser position?
Rüdiger (Rudi)
thanks 1 user liked this useful post by RudiC
#7 Posted : 31 October 2025 21:23:51(UTC)
Antonio Lopez P.
Panama
Marklin 3021 electrical test 1 video - 2025-10-31 at 14.00.02.mp4 (14,449kb) downloaded 9 time(s).
The attachment is a video with the continuity test. Please advise if it's done properly or not.
Antonio
Online RudiC
#8 Posted : 31 October 2025 22:39:09(UTC)
RudiC
From that video I infer that one half of the field coil is broken inside. I'm afraid you need a new coil.
Rüdiger (Rudi)
#9 Posted : 31 October 2025 22:48:57(UTC)
Antonio Lopez P.
Panama
Thanks Rudi.
Will go for it, guess have no other choice.
Thanks again
This page was generated in 0.324 seconds.
