Offline jonas_sthlm
#1 Posted : 28 October 2025 22:09:49(UTC)
jonas_sthlm
Is anyone running the latest TC 10 Gold B3 together with CS3 2.5.2(6)?
I’m having a problem when calibrating locomotives — they don’t stop at the start/stop block even if TC sowing active block status.
Both the PC and the CS3 are connected with cables to a router.
Offline pederbc
#2 Posted : 28 October 2025 23:22:06(UTC)
pederbc
Hi Jonas,
I have the same setup, TC gold 10B3 connected to CS3. But I haven’t experienced this behaviour.i use 3 sensors/block and it works. Is there anything in the logs?
Peder
Offline jonas_sthlm
#3 Posted : 29 October 2025 14:41:25(UTC)
jonas_sthlm
Sometimes I feel that CS3 lacks in communication, and the safest option is to use a wired network connection between PCs. The function buttons for the locomotives don’t always work, and occasionally there’s even a double activation. This mostly happens with locomotives that have a DCC protocol in the decoder.
Offline pederbc
#4 Posted : 29 October 2025 14:58:01(UTC)
pederbc
Hi again,
Actually, I don’t see any of these behaviours. Not from the CS3, nor from TC. I also use wifi connection using wifi6. The S88 network is routed through the CS3. Could there be any disturbances in the powerfeed to the rail? Do you get the same problem on the program track?
Peder
This page was generated in 0.454 seconds.
