Offline Simon cantski
#1 Posted : 23 October 2025 12:37:26(UTC)
Simon cantski
As a newcomer to Z scale I need a bit of help/advice. The line(old Rishworth Branch) I am building used to have a railmotor as its main passenger train. I have made one for my N gauge set up as a trial piece from a Langley kit but nothing is available for Z gauge. So I have to make one. For this I need either a donor steam engine that sort of resembles a small British tank engine and suitable carriage to cut about, remodel and paint or a couple of suitable donor chassis that I can re-engineer. Any suggestions?
I am sure some more problems will arise but just at the moment I am in the set out phase so all in control at the mo.
Thanks in advance
Simon
Offline Chas
#2 Posted : 23 October 2025 18:59:39(UTC)
Chas
Have mulled, length is a problem on z, try megga cheap option, rukuhan motor, split in to 2 halves, coach body atlas static delprado z, new zealand train carriage a possible, rummage for a atlas z static for the train body, , strip it out powered from the rear with rokuhan, Wheel config look reasonable, should go round tight curves. There was one posting here on an extened body.
If you cant buy it , bash it.
BOL
Chas
XXXX Get the motor from panzer down in Swindon, the type 2 is is abot 1mm smaller on width.
Offline Poor Skeleton
#3 Posted : 23 October 2025 21:21:21(UTC)
Poor Skeleton
Thanks in advance
Simon
You might want to look at the Rokuhan Shorty Chassis. It's relatively inexpensive and easy to lengthen. You won't have the valve gear etc, but maybe you could make something that looks the part. As far as I can remember, there have never been any 0-4-0 locos from Marklin, so that's not an option as a starting point, I'm afraid.
Have you considered 3D printing the body shell? Of course the 3D modelling is a bit of a learning curve and the printing process and materials have their limitations but it had a few advantages over scratch-building. If you look at this thread Using other bodies you can see what can be done with a shorty chassis and 3D printed body shell.
Hope this helps
Chris
Offline Chas
#4 Posted : 24 October 2025 07:21:07(UTC)
Chas
[ As far as I can remember, there have never been any 0-4-0 locos from Marklin, so that's not an option as a starting point, I'm afraid.
As an idea, an 8800, take the middle wheels off the axle?
Hope this helps
Chris
#5 Posted : 24 October 2025 10:43:36(UTC)
Simon cantski
Thanks chaps.
As to your observations so far..... Yes I had already bought a Rukuhan motor with that in mind but was struggling with the engine. I think the idea of an 8800 is prob the way to go and with some fettling as you suggest it should look the part. Like the idea of the Atlas coach and again with some (careful) 'bashing' it again will scrub up well. I will post a pic(if I can learn how to) when the job is done ....may be a while.
3d printing. Had looked at that some time ago for the 'N' stuff so maybe I will revisit, not for this job but sure it will become a handy tool.
AND who is this panzer down in Swindon? Is he a got that we should all know about?
Again thanks for your time
Simon
Offline Chas
#6 Posted : 24 October 2025 11:01:39(UTC)
Chas
Look on ebay for z-panzer
1:220 Z scale gauge AL-CO GE Boxcab for Rokuhan Shorty powered chassis.
My "go to" for shorties
This page was generated in 0.227 seconds.
