Offline mb300e4m
#1 Posted : 20 October 2025 19:25:15(UTC)
mb300e4m
Did the King Ludwig sets come with Lighted coaches. I have seen some video clips showing them with lighted coaches. Confused
Peter B.
In Sunny Florida most of the time.
Marklin, Trix Express, Trix Twin, Fleischmann, Liliput, Hornby Dublo, and Others, 2 & 3 Rail, AC, DC and Digital, Course Scale Wheels & Fine, 1935 to 1960s usually.
Online kiwiAlan
#2 Posted : 20 October 2025 20:04:27(UTC)
I beleive they are lit, as they have different catalog numbers for the digital and non-digital versions, because they use different voltage bulbs.
Offline Ross
#3 Posted : 20 October 2025 23:00:48(UTC)
Ross
Hi Peter,
Yes the coaches have controlled lighting with two decoders that control each coach.
For those that are interested see my article below.
2681 LED Lighting Upgrade
Ross
Online kiwiAlan
#4 Posted : 20 October 2025 23:56:14(UTC)
Hi Peter,
But he is asking about the King Ludwig sets, not the King Wilhelm which you are referencing.
The King Ludwig lighting is not controllable in the coaches for the digital set AFAIK, that wasn't done until the King Wilhelm.
Offline rhfil
#5 Posted : 21 October 2025 03:10:03(UTC)
rhfil
I am away from my set but if I remember correctly they have lighting but you need a loco with a powered rear coupling as none of the cars has a slider. The power out the coupling is a loco function so can be turned off and on. I have at shows replaced the loco in the set with the 37981 which has sound and power out the coupling. It is also almost appropriate.
Offline mb300e4m
#6 Posted : 21 October 2025 04:07:08(UTC)
mb300e4m
Thanks everyone for the responses. My set arrived today with two extra coaches, display stand and display box. The links in your posts should provide me with some good reading.
I am going put together a circular track around the Christmas Tree, the lights in the coaches and on the loco will make a nice display.
Thanks again from sunny Florida.
Peter B.
Edited by user 21 October 2025 16:50:38(UTC)  | Reason: Not specified
Peter B.
Offline Ross
#7 Posted : 21 October 2025 21:25:52(UTC)
Ross
Hi Peter,
Sorry I provided the wrong article 2681 above for your original question
I have also the 2680 King Ludwig set which I have updated with LEDs, see article below
2680 King Ludwig LED Light Upgrade
My advice don't have the bulb lighting on for too long as the bulbs get hot and may damage your train.
Peter B.
Ross
Offline Ross
#8 Posted : 21 October 2025 21:41:02(UTC)
Ross
Hi Alan,
Sorry for the wrong link a slip of 0 for 1.
The lights in the train are controlled from the locomotive.
Hi Peter,
Ross
Offline mb300e4m
#9 Posted : 22 October 2025 16:47:18(UTC)
mb300e4m
Thanks for the info and the links.
Peter B.
Peter B.
Online kiwiAlan
#10 Posted : 22 October 2025 22:23:41(UTC)
Hi Alan,
No problem, easy mistake to make.
This page was generated in 0.604 seconds.
