Offline JJ922
#1 Posted : 19 September 2025 23:10:41(UTC)
JJ922
Hi, new to working on models trains. I have a Marklin 3317 that I’m trying to upgrade to digital with sound. I have the sound working but the motor will not move forwards or backwards. Any thoughts would be great appreciated. TIA
-Jake
thanks 1 user liked this useful post by JJ922
#2 Posted : 19 September 2025 23:38:43(UTC)
Hi Jake
A warm welcome to this great forum.
If I am not mistaken the 3317 is a french steamer of Etat railways.
It was released in 1991 as a one-time serie.
It is fitted with a drum collector motor (DCM) with a coil inductor, suited for AC operation.
You don't say which decoder you are using
Märklin sound decoders mSD3 require you to change the motor (AC) into a DC one.
Märklin calls it an HDLA and for DCM motors you need a 60941
Only then can you drive the loco with a sound decoder.
If you wish to keep the existing motor, then there is a special decoder for "All current motors" in wired form (60906)
The loco will perform no better than it was in analogue (no load regulation), will have no sound but will understand analogue and digital in 3 formats MM2, DCC, MFX
Offline JJ922
#3 Posted : 20 September 2025 00:24:48(UTC)
JJ922
Cheers thank you for the reply. I have the high efficiency motor 60943, and am using the MSD3 decoder set.
Offline DB Fan
#4 Posted : 20 September 2025 01:51:54(UTC)
DB Fan
Hello
Did you install the brushes after the conversion? I forgot them before and took me a little to figure it outBigGrin .
Maybe a wire came loose? Happened to me also. It was in shrink tubing and only found it when I tugged on it and it came out. I would check everything over with the shell off on a programming track and would wiggle on some off the wires to see if the engine moves or some other reaction. Been there done that. Good luck.
Robert
Offline JJ922
#5 Posted : 20 September 2025 03:16:03(UTC)
JJ922
Originally Posted by: DB Fan Go to Quoted Post
Hello
Robert
Thanks, just checked it and it seems to be holding. What I have connected is:
Red to red
Grey to motor connection
Orange to motor connection
Browns to speakers (works properly)
Yellow to rear lights
White to front lights
Black to ground on motor
Maybe I did it wrong.
Offline DB Fan
#6 Posted : 20 September 2025 05:09:56(UTC)
DB Fan
Hello
I’m not that familiar with Marklin decoder wiring since I use ESU decoders. I think it would be helpful if you could post a picture of the wiring you did so others who are more familiar with the Msd3 decoder can take a look at it and can help with your problem. Sorry that I couldn’t be of more help.
Robert
Offline Normmeister
#7 Posted : 20 September 2025 09:16:01(UTC)
Normmeister
You have wired the loco to the colour code that everybody (except Marklin) uses.
The Marklin code is :
red and black (or brown): track connections.
blue and green : motor connections
orange : V+ common for lights etc.
from memory, yellow for front light, grey for rear light.
brown for speaker (I think).
Norm in Oz.
thanks 2 users liked this useful post by Normmeister
Online bph
#8 Posted : 20 September 2025 10:38:45(UTC)
Red to red
Wiring seems to be correct if you used a 60985 mSD3 decoder or similar, but it's wrong if you used a 60975 or similar. What did you use ? Do you have a picture of the installation?
Offline JJ922
#9 Posted : 20 September 2025 11:09:48(UTC)
JJ922
Red to red
The decoder is a 60985 kit, I can take pictures later in the day. Thank you
Offline cintrans
#10 Posted : 20 September 2025 21:46:12(UTC)
cintrans
Aruba
Jake
Your connections seem to be OK
What you could do is check with a volt meter / ohm meter if your circuit is OK
Measure on the poles of the motor (grey and orange wire) if voltage is reaching the motor, alternatively you could de-solder the wires and put a DC voltage straight on the motor (e.o. with a 9V battery or something) and see if the motor works like that.
Jean-Pierre
Offline Johnvr
#11 Posted : 20 September 2025 23:19:07(UTC)
Johnvr
Hello
Robert
Red to red
Perhaps just for clarity :
The black wire from the decoder goes to the chassis ground, but it must not touch any motor ground.
"Black to ground on motor "
By the way, I'm not sure which light bulbs you have in the locomotive.
If the light bulbs are grounded to the chassis ground, they will flicker with the AC current.
To prevent flickering of lights, you can connect the blue wire from the decoder as ground for the lights.
If you attach a picture of the lights, then we can see whether the lights should be grounded to the blue wire.
Offline JJ922
#12 Posted : 21 September 2025 18:15:11(UTC)
JJ922
Hello
Robert
Red to red
Thank you, I just reworded the motor and changed the ground spot for the black wire. The motor will move the train about 1” in reverse so I swapped the orange and grey wires. Now nothing not even sounds. Power is getting to the motor I believe, or at least it was.
Offline JJ922
#13 Posted : 21 September 2025 21:33:02(UTC)
JJ922
The engine will now run full speed in reverse with no working sounds or control.
This page was generated in 0.379 seconds.
