Offline luke_1
#1 Posted : 16 September 2025 06:48:04(UTC)
luke_1
China
My trix track is a very simple circle. Today, the model train suddenly couldn't pass through one of the straight tracks. I started to look for the cause and tested it with a multimeter. There was no problem with the power. I changed to another train and tested it, but the problem still existed, which meant that the problem was not with the train. Then I wiped the track with an alcohol sponge, but it still couldn't pass after the test. I don't know if there are other ways to find the cause?
thanks 1 user liked this useful post by luke_1
Offline Carim
#2 Posted : 16 September 2025 13:13:16(UTC)
Carim
Have you checked that there is nothing from the locos catching the track and so physically preventing the loco from moving forward? Does this happen in both directions?
Carim
#3 Posted : 16 September 2025 14:08:43(UTC)
Possible reverse loop short?
Offline rhfil
#4 Posted : 16 September 2025 15:48:13(UTC)
rhfil
Should not be a reverse loop short as it is a simple circle. Could check for that though by setting the multimeter on dc voltage and checking for whether the voltage changes from positive to negative on the track in question. Solution might be to replace the track in question or if no replacement is available remove it and the same track on the opposite side. If the problem continues then it is not the track.
Online RudiC
#5 Posted : 16 September 2025 22:53:41(UTC)
RudiC
To paraphrase what you wrote: You have at least two locomotives that run fine on most of your single circle layout but stop one one specific straight piece of track. Measuring the voltage on this dubious track shows no voltage loss vs. the other parts of the circle.
That's a strange error, and that's little information.
Some questions:
- Do the locos stop on exactly the same spot?
- Is it guaranteed they don't create a short circuit?
- Do they stop in forward as well as in reverse direction?
- Do they stop if turned around?
- Do they run if power is applied directly to the track piece?
- Did you exchange / replace / reverse the dubious track pieces?
- Did you check the continuity / resistance of the track connectors?
- Did you measure voltage with some load applied consuming, say, 0.5 - 1 Ampere?
- Did you measure at various voltage settings?
Rüdiger (Rudi)
thanks 2 users liked this useful post by RudiC
#6 Posted : 17 September 2025 22:20:57(UTC)
If you are using Trix C track (2 rail) and inadvertently include a section of Märklin C track (3 rail) you will get that odd circumstance.
Because when the locomotive wheels touch that section, the current on both rails will become the same polarity (postive or negative) and it will not run.
This happens because both brands of C track will clip perfectly into each other.
Online RudiC
#7 Posted : 17 September 2025 22:33:17(UTC)
RudiC
... using Trix C track (2 rail) and inadvertently include a section of Märklin C track (3 rail) ...
Wouldn't that short circuit the entire layout?
Rüdiger (Rudi)
thanks 1 user liked this useful post by RudiC
#8 Posted : 18 September 2025 00:07:35(UTC)
Thank you Rudic.
I believe I am correct, because the fine gaps between the C track rails at the connection point, isolate each section of C track if it were not for the undertrack connections.
I think I would need to test it, but that might take a few days to locate the parts.
The other questions might be what controller or power supply (analog or digital) Luke is using.
And then whether or not he gets a short circuit annunciation.
Offline LeoArietis
#9 Posted : 18 September 2025 13:54:23(UTC)
LeoArietis
Yes, it would short the layout, unless you cut the undertrack connections between the two strings of rail. When cut it would work just like a regular 2R-Trix, but with the extra studs in the middle not connected.
If there is no short my guess is the track is either faulty (one or both of the strings not connected) or dirty. Maybe try some other cleaning solvent like iso-propanol or heptane/octane or electric cleaner and rub the track with a cloth.
Current layout:
The former project:
thanks 2 users liked this useful post by LeoArietis
This page was generated in 0.557 seconds.
